01-23-2019
06:16
13:05
01-23-2019
06:16
13:05
Fitbit Charge 3 display not working, why? It was at 95 % charge
09-19-2019 07:39
09-19-2019 07:39
I have reset my fitbit and the display returns for about 10 minutes. I have had to reset it multiple times a day. Why does it stop displaying and how do I get it to stop stopping?
09-22-2019 22:49
09-22-2019 22:49
My Fitbit charge 3 has the same horizontal lines. I’ve changed the clock face and rebooted and still have the problem. What’s the next step to fix it?
09-23-2019 01:02
09-23-2019 01:02
Hi I had the same problem with my Fitbit Charge 3 Display Screen. And I did all the things that was possible so in the end I got in touch with Fitbit Customer service. I told them what the problem was. So now I have a new Fitbit Replacement
Best Answer10-23-2019 04:10
10-23-2019 04:10
Hello can anyone help!
I have a Fitbit charge 3 and the display is not working. I have tried to reset it over 10 times now using the instructions online and it continues to synch to my phone, tracking my steps etc however the display is blank. It’s still vibrates.
Thanks
10-23-2019 06:37
10-23-2019 06:37
Best Answer10-23-2019 06:54
10-23-2019 06:54
Changing the watch face worked for me. I then reverted to my previous watch face, and it seems that all is well.
Best Answer10-23-2019 09:52
10-23-2019 09:52
10-24-2019 20:19
10-24-2019 20:19
Best Answer11-11-2019 04:25
11-11-2019 04:25
is method worked much better than changing the clock face. Thanks!
Best Answer11-11-2019 10:53
11-11-2019 10:53
Hi I have tried to reset my fitbit afrer it went black screen by connecting to the charger ,& holding the side button for 8 secs as suggested. I now have the smiling face frozen on my screen & it's not charging- any suggestions?
11-11-2019 18:38
11-11-2019 18:38
11-22-2019 05:14
11-22-2019 05:14
Wow! Thanks! Your recommendation worked like a charm!
Best Answer11-22-2019 10:13
11-22-2019 10:13
I didn't see the I instruction on what to do on fixing the black scree
Best Answer11-23-2019 15:14
11-23-2019 15:14
Please help! Screen black, but vibrations are working. I have down clockface changes and hard reset. Screen is still black. Help!
11-25-2019 12:25
11-25-2019 12:25
I changed the clockface and it worked thank god
Best Answer11-25-2019 13:05
11-25-2019 13:05
My display has also stopped working. I have attempted to restart it and change the watch face with no luck. How do you contact customer support?
Best Answer12-02-2019 21:15
12-02-2019 21:15
Hi - my Charge 3 has gone blank (again) the first 2 times this happened I was able to re-set using the charge & hold method, this last time I tried the clock face change - that worked for 30 minutes then it went blank again & now I cant get anything to work.
Would really like to get this working please.
Thanks for any help
Best Answer12-03-2019 04:45
12-03-2019 04:45
12-03-2019 05:06
12-03-2019 05:06
My screen went black for the third time and I am at work and don't have the charging cable. I held the reset button in for about 60 seconds and the screen FINALLY came back on. Clearly this is a major Fitbit issue which I am sure that they are aware of. Fitbit has no reason to fix it because people are still buying the watches. The Sys-Op just keeps cutting and pasting the same response to everyone who inquires about a screen issue. Eventually when we all stop purchasing this product THEN the glitch will miraculously be repaired. 😞
12-03-2019 07:21
12-03-2019 07:21
