12-19-2018
07:18
14:31
12-19-2018
07:18
14:31
Try selecting a different clock face within your phone app. My watch is about 3 months old, upgraded a 4 year old Fitbit. Last evening when reading, I noticed an unfamiliar vibration with my Charge 3. When I looked at the display, blank/black. When I went to manually activate the display, blank. I had just charged it the day before, so that couldn’t have been the problem.
My phone stats seemed to be working. Searched problem, went through reset process, nothing. This morning same, blank display, but my phone indicates it’s still tracking sleep and steps. I tried everything again to get the display to work, nothing. I was getting ready to call customer support when I happened to read one post that they simply changed the clock face within the phone app. Wow!! I know, it makes no logical sense to me either, but It’s working, at least for now, I love the watch, but for the price, apprehension has set in, I’m now promoted to question the quality of the product. This should not have happened. I’m taking a we’ll see approach.
12-20-2018
03:23
09:16
12-20-2018
03:23
09:16
It's great to see new faces @DMHunter, welcome!
I appreciate the efforts in trying to fix this issue, it's great to hear that you got your tracker to work again by changing the clock face. I know a lot of people will find this tip really helpful. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up! ![]()
Best Answer01-20-2019 09:07
01-20-2019 09:07
Had the same issue and this worked.... thanks!
03:07
09:16
01-21-2019
03:07
09:16
Hey @Steelruby17, welcome to the Community. It's great to hear that the tip provided by our friend helped you and that your tracker is now working as it should. If you need help in anything else, do not hesitate to let us know.
Happy stepping! ![]()
Best Answer04-17-2019 14:27
04-17-2019 14:27
Hi Alejandra,
I had same issue today. Is fitbit working to resolve this?
Mark
04:23
09:15
04-18-2019
04:23
09:15
Best Answer04-20-2019 12:09
04-20-2019 12:09
I follow this recommendation and it works.
For now, the problem solved.
Is Fitbit will make an effort to find a better solution?
04-21-2019
04:33
09:10
04-21-2019
04:33
09:10
Hey @Ranay-2167, welcome to the Forums.
I am glad to hear that the instructions provided worked and that your tracker is now working properly. I would ask you to keep an eye on your tracker, and in the case this happens again, please let me know and I will be glad to further investigate.
Keep the stepping up! 🙂
Best Answer02-18-2020 16:12
02-18-2020 16:12
I had exactly the same issue, and the same fix worked. Suddenly the display when completely dark, though the Charge3 appeared to be working correctly in all other respects. I changed the clock face to a different one, and back on it came. Then switched back to the original face ... and for now still working. I should add that this is a replacement unit I got from Fitbit (good customer service when the prior one fried. It's all of a few weeks old.
