10-10-2018
13:58
15:47
10-10-2018
13:58
15:47
Hi my new charge 3 is blank and when I charge it and try to restart it using the side button it just vibrates with a blank screen.
02-25-2019 17:52
02-25-2019 17:52
This seems to be way too common of an issue... It seems my device is doing the same as most people on here. A couple days ago, I noticed the screen wouldn't turn on and just assumed it was dead somehow. I plugged it in and went to work. Now I just sat down to try and figure this out... The fitbit vibrates when I press the side button, I can plug it in and hold the button for 8 seconds and see the smiley face for about 10 seconds and then it turns off again. Now, the last solution I read is to change the watch face.... Great idea, but the fitbit is not connecting to my phone and the screen won't turn on. Any other ideas?
02-26-2019 05:30
02-26-2019 05:30
Hello guys, thanks for your participation in the Community.
@ColtBurkhardt, it's great to hear that the instructions provided worked and that your tracker is working properly now. If there is anything else we can help you with, do not hesitate to post it.
@SunsetRunner, since the steps provided didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
@Jaydawgx7, if your tracker isn't syncing, I recommend following the instructions provide in the help article Why won't my Fitbit device sync? and after it syncs, try to change the clock face.
Let me know how it goes.
02-27-2019 04:40
02-27-2019 04:40
Mine was doing the same thing. I just changed the clock face and then my screen turned back on.
02-27-2019 20:51
02-27-2019 20:51
I forgot to wear my Fitbit on Monday. Sunday it was working just fine. So Monday after work I put the Fitbit on the charger since it seemed like it was dead. It stayed on the charger over night and all day Tuesday. Today (Wednesday) I put it on my wrist but the screen would t turn on. When I pressed the button on the side, it would just vibrate.
02-27-2019 21:46
02-27-2019 21:46
This work perfect for me. Put it on the charger and held the button down until a 🙂 came on. Working perfectly now. Thank you
02-28-2019 06:43
02-28-2019 06:43
Blank Screen but was still syncing fine. so I tried changing the clock face and it did the trick for me.
02-28-2019 06:46
02-28-2019 06:46
So happy it worked.
03-01-2019 01:43
03-01-2019 01:43
Why is that happening my display only came back on when I joined it with the charger and held button plenty of battery life! Doesn’t give me confidence in the product:(
03-01-2019 04:56
03-01-2019 04:56
Just tried this and a smiley face came on and do did my watch. Thanks for your help.
03-01-2019 22:04
03-01-2019 22:04
My Charge 3 display has gone black, it was fine one minute, now blank I have charged it fully and pressed the side button but still the screen remains blank
03-01-2019 22:41
03-01-2019 22:41
Thanks for this. I just followed your steps and its finally working again.
03-02-2019 02:31
03-02-2019 02:31
03-02-2019 04:03
03-02-2019 04:03
Same problem, black screen
never had issues with Fitbit until I got
the charge 3 please help resolve this problem this is very frustrating
03-02-2019 04:57
03-02-2019 04:57
03-02-2019 05:21
03-02-2019 05:21
03-02-2019 06:06
03-02-2019 06:06
Hi everyone, hope you are doing well!
I appreciate all the efforts in trying to fix this display issue by yourselves. @SunsetRunner and @TWong2019 thanks for the input.
@Ballerinabyrd, @apcb17, @Yjrussell, @Pollies, @Chick268 and @Quzaisaeso, it's great to hear that changing your clock face or restarting your devices worked and that your trackers are now working properly. If there is anything else we can help you with, do not hesitate to post it.
@PMenard, @Janetcarter, @Dsplese and @Becw2, if your trackers aren't turning on, I recommend taking a look at this post and follow the instructions provide there.
See you later.
03-02-2019 06:35
03-02-2019 06:35
03-02-2019 07:13
03-02-2019 07:13
03-02-2019 08:55
03-02-2019 08:55
My Charge 3 did the same thing, screen is black and have tried suggested repairs. Nothing.
03-02-2019 10:32
03-02-2019 10:32
Ditto, Thanks
