10-10-2018
13:58
15:47
10-10-2018
13:58
15:47
Hi my new charge 3 is blank and when I charge it and try to restart it using the side button it just vibrates with a blank screen.
03-24-2019 19:36
03-24-2019 19:36
Worked for me.
03-24-2019 21:52
03-24-2019 21:52
03-25-2019 06:35
03-25-2019 06:35
After not using for quite a while, I charged my device over night and it will not turn on.
03-25-2019 07:14
03-25-2019 07:14
Try holding reset button for 8 seconds while fit bit is on charger.
03-25-2019 11:01
03-25-2019 11:01
I've had my charge 3 for 12 weeks. Always worked great till yesterday. I was not able to charge it at all. No screen no vibration no sync, nothing. Left it charging overnight but still nothing.
03-25-2019 11:06
03-25-2019 11:06
03-25-2019 11:30
03-25-2019 11:30
Thanks, but it's dead. not just blank screen, no green heart rate light, no vibration and no sync to phone.
03-25-2019 12:09
03-25-2019 12:09
Same happened to me yesterday. Reid resetting on charger and it didnt work. I changed the clock face to a new face and then back to the one I liked and it came back on!
03-25-2019 12:20
03-25-2019 12:20
Mines is the same. Blank screen ive tried a restart and no joy 😢
03-25-2019 20:46
03-25-2019 20:46
Fixed!! Plug your fitbit into the charger... Then hold down button for 15 seconds... Smiley face should appear. Done.
03-29-2019 14:03
03-29-2019 14:03
My fitbit will charge, when I put it on the screen goes black after about 5 minutes. What could be wrong?
03-29-2019 14:14
03-29-2019 14:14
Finely having a replacement sent, fingers crossed it will work. Took a lot of emails to get anywhere though. If I could of found the box it came in I'd of phoned QVC up and asked for a refund. Good luck
03-29-2019 15:24
03-29-2019 15:24
03-30-2019 04:41 - last edited on 05-31-2020 15:40 by LiliyaFitbit
Ill try that. Thanks
Get Outlook for iOS
03-30-2019 06:21
03-30-2019 06:21
03-30-2019 06:31
03-30-2019 06:31
03-30-2019 06:52 - last edited on 05-31-2020 15:39 by LiliyaFitbit
Got it. The update did the trick!! Yeaaaaa. Thanks. I was obsessing a tad!
Get Outlook for iOS
03-30-2019 10:57
03-30-2019 10:57
Same problem here with a few months old Charge 3. But this trick helped us out. Pushed the button for 10 seconds while hooked up to the charger and then a happy face appeared. Thanks for the tip.
03-30-2019 11:00 - last edited on 05-31-2020 15:39 by LiliyaFitbit
Thanks. Tried that. No happy face. I got it to display longer while wearing it. Goes black now after about an hr. Works fine on charger.
Get Outlook for iOS
03-30-2019 11:40
03-30-2019 11:40
