10-10-2018
13:58
15:47
10-10-2018
13:58
15:47
Hi my new charge 3 is blank and when I charge it and try to restart it using the side button it just vibrates with a blank screen.
04-30-2020 18:14
04-30-2020 18:14
04-30-2020 18:14
04-30-2020 18:14
Get an Apple Watch. For $50 more, it is more than worth the money! Especially if you have an iPhone
04-30-2020 18:24
04-30-2020 18:24
Best Answer04-30-2020 18:29
04-30-2020 18:29
Best Answer05-01-2020 06:03
05-01-2020 06:03
Best Answer05-01-2020 06:05
05-01-2020 06:05
I went into the app and changed the clock. Waited a few minutes. Then changed it back. And it started working again. I haven’t had any trouble cents. And it’s been quite a while ago. Good luck
Best Answer05-25-2020 17:32
05-25-2020 17:32
I have charged my fitbit3 to 100% and have repeatedly popped it into the charger and holding down for the fifteen seconds. I have also changed the clock face and still nothing. I have gone for a short walk and it is still logging my steps but my display is black and unresponsive. What is the next step? Thank you for any help.
05-25-2020 17:57
05-25-2020 17:57
I have the same problem. I can’t find a clock to download for my charge 3. I want an analog watch face cause I can’t read the numbers without my glasses
Best Answer05-25-2020 18:04
05-25-2020 18:04
Hi there,
I have been using an analog clock all along and I've had my fitbit 3 for over a year. When I go into the option for "all clocks" I have fifteen to choose from and two are analog: Analog Date and Analog Stat. Have you checked all of your options? Mine still isn't working although I have taken all of the steps that have been suggested so I hope you have better luck!
Best Answer05-25-2020 19:20
05-25-2020 19:20
I found the other clock faces, but like you said only two analog ones are available but even the other ones won’t load turn my screen back on. I can’t understand why I just don’t have any luck with these Fitbit watches. This is from last December 2019 and stopped working end of April 2020.
Best Answer05-25-2020 19:29
05-25-2020 19:29
Best Answer05-25-2020 22:20
05-25-2020 22:20
Best Answer05-25-2020 22:31
05-25-2020 22:31
I had the same issue with my Fitbit charge 3. I had to restart it for 3 times and still no work. I able to change clock faces in the app bit still no display on my fitbit screen. Please advise on how to fix this. Thank you in advance
Best Answer05-26-2020 04:29
05-26-2020 04:29
So, I had the screen display issue, couldn't be resolved, and on 9/19/19 got a new Charge 3.
Screen has died again, and, not only that, the battery won't charge at all. I had tried all the fixes we went through before. Can't try anything else, now, because it died and I can't get it to take any charge at all.
Best Answer05-26-2020 04:33 - last edited on 05-31-2020 15:37 by LiliyaFitbit
thank you!!
Get Outlook for iOS
Best Answer05-26-2020 09:20
05-26-2020 09:20
What do I do when when the smiley face comes on, but the screen is still black?
Best Answer05-26-2020 16:40
05-26-2020 16:40
05-26-2020 16:45
05-26-2020 16:45
05-26-2020 16:53
05-26-2020 16:53
Best Answer05-26-2020 16:56
05-26-2020 16:56
