10-10-2018
13:58
15:47
10-10-2018
13:58
15:47
Hi my new charge 3 is blank and when I charge it and try to restart it using the side button it just vibrates with a blank screen.
09-16-2020 12:17
09-16-2020 12:17
Unfortunately, changing clock face and getting a smiley face has not worked for me.
10-06-2020 09:36
10-06-2020 09:36
Hello, My FIT Bit Charge 3, after doing fix, stays blank, is there another fix known?
Best Answer10-06-2020 17:01
10-06-2020 17:01
Hi This method totally can’t work for my charge 3 still dark screen
Best Answer10-06-2020 17:51
10-06-2020 17:51
I have tried the start and the long restart and nothing has worked.
Best Answer10-06-2020 20:35
10-06-2020 20:35
I have been having the exact same issue with my Charge 3 after having a swim last Friday. I'm feeling very lost without it & have tried everything suggested to try to resolve the issue but to no avail 😥
Best Answer10-06-2020 20:52
10-06-2020 20:52
My fitbit charge 3 display isn't working. I have tried changing the watch face and both restart methods suggested. Is there any other thing I might be missing? My charge 3 battery I charged.
Best Answer10-07-2020 01:29
10-07-2020 01:29
Best Answer10-10-2020 06:04
10-10-2020 06:04
hey there,
I tried doing that but my watch doesn't start or shows a smiley face . it just vibrates when put on charge . and it has disconnected from the bluetooth of my phone and it won't connect again . i have no clue what to do .
just waiting for the right answer where i can repair it . it would be very helpful if you reply .
thank you,
Shubham kedia
Best Answer11-21-2020 08:28
11-21-2020 08:28
Have tried all of the above suggestions still vibrates with blank screen. Screen was fading, did update still had faded screen, tried restart, screen now black. Have changed clock face, restarted multiple times, still black screen. I am reluctant to go back to factory settings. Should not have to replace a device that is 31 months old.
11-21-2020 11:04
11-21-2020 11:04
Correction 21 months old.
12-25-2020 17:11
12-25-2020 17:11
This issue has plagued me for the past year as well. On 2 occasions by following the troubleshooting steps I was able to get the display to work again. Unfortunately the 3 time this happened was the last time the watch would ever display even after performing all troubleshooting steps. I inquired about the warranty, it was too late, my warrant period had just expired. My advice is if you are experiencing this issue exercise your warranty for a replacement instead of troubleshooting - as it is only a temporary fix. I was offered a 35% discount toward the purchase of a new Fitbit. I have no interest in taking the risk on buying a new Fitbit given this well know issue and lack of proactive measures to notify customers by Fitbit.
Thanks, Sarah
12-26-2020 14:20
12-26-2020 14:20
01-30-2021 10:04
01-30-2021 10:04
I bought a charge 3 last boxing day with in 3 months it stopped working will not sync or connect to anything.or won't keep time It it now12 hrs behind. I cleaned the back of the watch and charger...tried using different chargers...left it rest for a few weeks....now just vibrates with black screen
01-30-2021 10:14
01-30-2021 10:14
I held the power button for 20 seconds after that it just stops vibrating but no change
01-30-2021 13:54
01-30-2021 13:54
01-30-2021 14:56
01-30-2021 14:56
I just wanted to post my feelings about the Charge 3.
My wife has had a Charge 3 since end of 2018.
Due to various problems; water ingress, battery not holding charge, black lines on screen, she has had it replaced 5 times over the last two years - all under warranty.
Finally we can be shot of this Fitbit fiasco as the 6th unit has now failed with a totally blank screen and now outside of warranty.
We couldn't be bothered to contact support as even if their discount was 75% we would never touch another shoddy product like this again.
Best of luck to all remaining Charge 3 (and maybe Charge 4) owners.
04-02-2021 08:09
04-02-2021 08:09
I am also having this problem. I have also done the hard restart which brings the display back for a minutes and then nothing. When it is on temporarily I cannot swipe through the screens. My fit bit charge 3 isn’t that old and this is how my other one died.
Best Answer05-15-2021 04:08
05-15-2021 04:08
Thanks for sharing this Alejandra. Mine is a bit of a peculiar problem. I have done both the 8 and 15 secs restart none has worked.
Now I can't try the changing the clock face option as I am using a new device now and pairing it requires that I see the number on the display which not coming on. Can you help with any other suggestion for me?
Best Answer05-15-2021 09:02
05-15-2021 09:02
Best Answer05-15-2021 11:52
05-15-2021 11:52
