10-10-2018
13:58
15:47
10-10-2018
13:58
15:47
Hi my new charge 3 is blank and when I charge it and try to restart it using the side button it just vibrates with a blank screen.
01-25-2019 13:59
01-25-2019 13:59
I have full battery, screen display will not turn on. Back of screen green light on. Haven’t had my charge 3 for 1 month yet.
01-26-2019 06:38
01-26-2019 06:38
I just used the advice from a few posts below. Put your Fitbit on the charger and hold the side button in few a few seconds. I couldn’t believe that it turned on! I almost ordered a new one.
01-26-2019 12:27
01-26-2019 12:27
Very disappointed with the charge three. I graduated from the Fitbit zip to the Fitbit Alta and then to the charge three in August. In October it did the same thing fully charged and went and screen went black. Tried leaving it off for a day with no change. Called HSNN they happily exchanged for a new one. It's January now and a repeat of the black screen. My first two fit bits are still working . It's not like you spent 20 or $30 Anten just dismiss as a junk product. With all the technology available today , All the kinks should have been worked out before putting on the market. I think I'm going to look into Garmin and check out their trackers.
01-26-2019 13:54
01-26-2019 13:54
Put it in the charger, and change the clock face via the FitBit app. Yes, it's stupid, but it works.
01-26-2019 14:15
01-26-2019 14:15
I am having the same problems as the others I this community forum. Blank screen, buzzes when the side button is pushed. I have a full charge on the Charge 3 device. Please answer back. Thank you! DJW918
01-26-2019 15:16
01-26-2019 15:16
01-26-2019 15:35
01-26-2019 15:35
Same problem. Black screen that syncs and vibrates but won’t turn on to show the display.
01-26-2019 15:37
01-26-2019 15:37
01-26-2019 17:06
01-26-2019 17:06
01-26-2019 23:58
01-26-2019 23:58
My fitbit did the same thing today. Try changing your clock design. I tried and it worked first try. Changed it back to my original design to see if it was just that clock face but it worked after switching it back. Hope this helped.
01-27-2019 04:26
01-27-2019 04:26
I had the blank screen yesterday, fully charged it and that didn't help.
I did like many others and put it on the charger and hekd side button for 10 seconds. Smiley came up.
Wonder when this bug will be fixed.
01-27-2019 09:14
01-27-2019 09:14
HOW I SOLVED IT
I had the exact same symptoms - worked fine but suddenly wouldn't turn on the display. Plently of charge remaining, would vibrate when the button was pressed, would vibrate when connected to charger, and would even vibrate at the '10 minute warning' if I hadn't done enough steps that hour. I also noticed it wouldn't sync. Very frustrating.
I tried a reset while connected to the charger with no luck, then I remembered the Sync issue so I TURNED OFF BLUETOOTH ON MY PHONE then did the reset while connected to the charger and everything came back to life.
I wonder if theres some sync/bluetooth crash or loop it gets stuck in preventing the display from activating? Who knows. I hope my method works for orhers.
01-27-2019 10:26
01-27-2019 10:26
I had the same issue but I could see via my phone app that it was fully charged and was recording my steps. I changed my clock face and my display was there again. Maybe this will work for others who have the same problem.
01-27-2019 19:21
01-27-2019 19:21
I’ve had my charge 3 for about a month. I was at dinner and it just stopped lighting up. It continues to vibrate when texts and calls come in but I cannot see anything. I tried restarting multiple times. I set it to charge for half an hour after it was pretty well charged originally then tried again. There is no change. How can I get this to work again?
01-28-2019 02:51
01-28-2019 02:51
I had the same issue. I tried your suggestion and Fitbit came on with the smiley face. Thank you!
01-28-2019 06:23
01-28-2019 06:23
01-28-2019 07:32
01-28-2019 07:32
01-28-2019 07:47
01-28-2019 07:47
I did that and it totally work!!!! Thank you
01-28-2019 09:26
01-28-2019 09:26
01-28-2019 09:53
01-28-2019 09:53
Welcome on board @fitmahmud, @debbiesop, @Pickles11, @Japaran, @hannahmdejong, and @TBrown16! I'm really sorry to hear about the inconveniences you've been having with your Charge 3. While reading your post I was wondering if you've tried the recommendations provided here? Are you getting any kind of error or message on the display? What happens when you let the tracker charging? Vibration? Fitbit icon? Nothing at all after 1-2 hours in the charging cable?
Hi again guys @NJ3A, @SunsetRunner, @ppockets, @sfair5, @LonePalmBJ! Thanks a million for your contribution here. Glad to have you around!
Glad to hear the tips and recommendations provided along this thread have been of help to you guys @davidbauguess, @i2avi, @dare6559, @5cramblez, @Johnula, @G-Daddy-Ken, @Bigelot22, @Yor14, @HelenB59, @brentieh, @Nanlok.
Let me know if you guys need further help!
