10-10-2018
13:58
15:47
10-10-2018
13:58
15:47
Hi my new charge 3 is blank and when I charge it and try to restart it using the side button it just vibrates with a blank screen.
01-30-2019 07:11
01-30-2019 07:11
01-30-2019
08:06
10:58
AlvaroFitbit
01-30-2019
08:06
10:58
AlvaroFitbit
Fitbit is sending a replacement. It will be here next week. Thanks for all the help.
Moderator edit: removed personal information
01-30-2019 11:56 - edited 01-30-2019 12:00
Same problem, device appeared to be working, vibrating and all, but no display. Holding button for 8 seconds (until second vibration) while device was in charger cleared things up.
01-30-2019 14:23
01-30-2019 14:23
I am having the same issue. Mine was fine and then all of a sudden the screen is blank. It is still syncing with the app, the green light is flashing, it vibrates when I get text messages or need to move. Resetting it doesn't help. Holding down the button doesn't help. Suggestions?
01-30-2019 19:36
01-30-2019 19:36
Thank you!! This worked for me! Plugged Fitbit into charger and held the side button for 10 seconds. A smiley fave came on then started working again 🤷🏻:female_sign:
01-30-2019 20:42
01-30-2019 20:42
Mine did the same so I tried syncing which worked but didn't fix it. Next I tried changing the clock face (recommended fix when my versa did the same), this did the trick on mine. I will however never be buying a fitbit again as this is the second watch that has done it and they are not cheap. #fitbithasissues
01-31-2019 03:59
01-31-2019 03:59
Hi guys, I hope you are doing fine.
I appreciate all the efforts in trying to fix this display issue by yourselves. @SunsetRunner, thanks for the input.
@jcrieff, @Barbarahut1, @AngieMc18 and @Kelly200 I am glad to hear that your issue has been resolved and that your trackers turn on or that you will be receiving a replacement. If there is anything else we can help you with, do not hesitate to post it.
@Neematessa77, @RogerMexico and @Dkemp, have you tried to change your clock face? If you haven't, I recommend trying this by following the instructions provide in the help article How do I change the clock face on my Fitbit device?.
Keep me posted.
01-31-2019 04:45
01-31-2019 04:45
01-31-2019 04:50
01-31-2019 04:50
01-31-2019 05:18
01-31-2019 05:18
Those are great news @Dkemp and @Neematessa77. It's great to hear that your trackers are now working properly. If there is anything else we can help you with, do not hesitate to post it.
Happy stepping!
01-31-2019 11:43
01-31-2019 11:43
I got my Fitbit charge 3 less than a month ago and for no reason the screen is gone blank. It’s vibrating when I try reset and it’s fully charged.
How can I fix it? 😭
01-31-2019 11:46
01-31-2019 11:46
01-31-2019 12:30
01-31-2019 12:30
01-31-2019 13:04
01-31-2019 13:04
I reset the clock face from my phone and it came back on
01-31-2019 14:01
01-31-2019 14:01
01-31-2019 16:49
01-31-2019 16:49
I was having the same problem with the blank screen and just vibrating. Held the button down for 10 seconds while on the charger, got the smiley face and now back to normal.
01-31-2019 18:32
01-31-2019 18:32
01-31-2019 19:00
01-31-2019 19:00
02-01-2019 03:31
02-01-2019 03:31
Hey guys, thanks for your participation in the Community.
I appreciate the input @SunsetRunner and @Pepper28,
@cloda11, as recommended by our friends, please try to change your clock face by following the instructions provide in the help article How do I change the clock face on my Fitbit device?.
@Tonzbee, @raiderjack, @Ansbach and @Gilcole, it's great to hear that your trackers are working properly now. If there is anything else we can help you with, do not hesitate to post it.
See you later.
02-02-2019 10:41
02-02-2019 10:41
Support just fixed mine. After attempting the reset to no avail, they had me go into the app, change the clock face and sync the device. The screen came back immediately.
