10-10-2018
13:58
15:47
10-10-2018
13:58
15:47
Hi my new charge 3 is blank and when I charge it and try to restart it using the side button it just vibrates with a blank screen.
12-01-2018 08:34 - edited 12-01-2018 08:39
I was having the same issue. I just tried the method of leaving it on the charger and holding down the button until it reset and through some sort of voodoo, it worked.
12-01-2018 09:12
12-01-2018 09:12
I have been using my Charge 3 for about 2 months quite successfully, but the screen went from being fully functional to completely black. When charging and syncing to my phone, I see that the Fitbit is nearly 100 % charged...so battery is not the issue. I have been holding the "button" and I feel the fitbit vibrate. I count to 8 to 12 seconds and release. No response after several minutes...any suggestions please?
Very disappointed as this seems to be a problem given the number of posts.
12-01-2018 09:29
12-01-2018 09:29
I had the same problem. I pre-ordered the Charge 3, have been using it for a while and it has been fine. Then this morning, it vibrated so I looked to see if I had a message and the screen would not come on. If I pressed the button on the side, it would vibrate but still no screen. I looked on this forum and tried the suggestion about putting it on the charger and holding down the button until the happy face comes on and it worked for me. Clearly, this is an issue many people are having and I hope that Fitbit addresses it.
12-01-2018 19:38
12-01-2018 19:38
I had the same exact experience with my Fitbit Charge 3 today as well 😞
12-02-2018 07:10
12-02-2018 07:10
I had the same issue.
Possible work around that worked for me. Open phone app. Change your clock display face selection on your app and apply. When I did that the display magically came back. I set it back to my preferred clock face and it continued to work.
Dunno, guess it's a bug.
12-02-2018 07:31
12-02-2018 07:31
I bought my charge 3 today and have just set it up. I just get a blank screen and the side button vibration when it comes off the charger. Seems like many users have the same issue. Please advise.
12-02-2018 08:21
12-02-2018 08:21
Don't know if anyone else has done this but I changed my clock face on app which reconnected with watch and yay working again. Had same problem and drove me mad. Quick fix hopefully will work for some
12-02-2018 09:42
12-02-2018 09:42
Having the Same issue...bought the charge 3 in the last 90 days and display wont go on...appears to be synching and counting...now what? Please advise. Thank you
12-02-2018 14:21
12-02-2018 14:21
Return it back dear..
because your charge 3 still in the
guarantee
12-02-2018 14:23
12-02-2018 14:23
Return it back ..
because your charge 3 still in the guarantee..
12-02-2018 14:48
12-02-2018 14:48
ja nou lekker is dat allemaal, ook ik heb nu een zwart scherm.... de charge 3 zou een verbetering zijn van de 2.. heb 'm nu 5 weken.... en nu ???
12-04-2018 09:45
12-04-2018 09:45
Thanks! It works!
12-04-2018 16:23
12-04-2018 16:23
Hey @AngeGTb, I was thinking I'd have to go return mine because I was stuck with the blank screen and connecting/pressing the side button wouldn't work. I tried your workaround (change clock face on app) and THAT did the trick, so thanks.
12-05-2018 10:17
12-05-2018 10:17
Changing the clock face was the only thing that worked for me!
12-05-2018 10:18
12-05-2018 10:18
Mine is now doing the same thing. Just a blank screen. But stil vibrates when touched. I attempted to reset, charge, leave pff for awhile, nothing is making it work again. I purchased this directly from Fitbit....can i return??
12-05-2018 11:51 - edited 12-05-2018 11:52
I have been having this same issue and was on the verge of returning the fitbit, but I tried the solution posted by CVShort. Connected to charger, held button for exactly 10 seconds, got the smiley face, disconnected from charger and now my fitbit is on.
Thank you for posting. We'll see if this holds!
12-05-2018 14:01
12-05-2018 14:01
Tried a few resets with no joy! Changed the clock face in the settings to a new one and surprise it worked! Hope this helps!
12-05-2018 15:30
12-05-2018 15:30
Thank you it got mine working. Pissed to see it didn’t track my steps all day, no telling how long that’s been going on, I don’t look at it often
12-05-2018 15:35
12-05-2018 15:35
12-05-2018 17:32
12-05-2018 17:32
Same problem here but I have had it a month
