10-10-2018
13:58
15:47
10-10-2018
13:58
15:47
Hi my new charge 3 is blank and when I charge it and try to restart it using the side button it just vibrates with a blank screen.
12-05-2018 23:19
12-05-2018 23:19
Best Answer12-07-2018 12:12
12-07-2018 12:12
I was having the same issue as the other posters and I tried changing the clock face on the Fitbit App as suggested and it worked! This is a great temporary fix but hopefully Fitbit can issue a permanent fix.
Best Answer12-07-2018 13:19
12-07-2018 13:19
Great to hear!
let’s hope so 😊
Best Answer12-07-2018 21:21
12-07-2018 21:21
Having this same issue which is ironic since I had it on my HR2 after a year. This one I've had for about a month and screen went blank after charging and won't come back on.
Best Answer12-08-2018 23:00
12-08-2018 23:00
Very disappointing.
My Charge 3 display is completely blank although the tracker still syncs with the dashboard on my mobile. I’ve tried charging and ooressubg the button to try to reboot but no joy!
ive only had it a few weeks.
Best Answer12-08-2018 23:24 - edited 12-09-2018 00:12
Try opening up the FitBit app from your phone and click on your watch in the top left corner of the screen.
Change the watch face to something different.
Restarted the watch and the fitbit mobile app.
Set the watch back to its original view.
Everything should be working normally again as long as the device can still communicate actively with your phone or mobile device. Any sort of runtime system that is continuous can experience issues; in this case, possibly your Charge 3 watch face which transmits to your display. If this were to act or become corrupted, then your display may appear to have stopped working. Even a restart won't fix it if something became corrupt. Write back a new watch face to the watch, which will correct any corruption present before, and you should be on your way!
Please let me know if this works for you.
Best Answer12-09-2018 05:58
12-09-2018 05:58
Best Answer12-09-2018 06:03 - last edited on 07-06-2020 17:43 by LiliyaFitbit
I have just this minute solved the problem by re booting the tracker. I
was about to get in touch.
Thanks for your help.
Best Answer12-09-2018 06:05 - last edited on 07-06-2020 17:43 by LiliyaFitbit
I have this minute solved the problem by re booting the tracker.
Thanks for your help,
Best Answer12-09-2018 09:44
12-09-2018 09:44
Mine has just done the same. What did you do?
Best Answer12-09-2018 09:46
12-09-2018 09:46
@Knightmare wrote:I have the exact same problem. My Charge 3 was working perfectly one minute then I look down and it was a blank screen. It was at 96% charge last time I checked on it which was half an hour before it turned off. I went to plug it in and nothing happened, it didn't vibrate, the screen just stayed black. I thought maybe the battery died so I kept it plugged in for 2 hours, nothing happened, it just got really warm. I tried to press the button on the side in hopes to restart it, but again nothing happens, just a black screen. I don't know what to do. Should I keep it on the charger and wait to see if It'll turn on? Should I just send it back for a new one? Am I just wasting my time on this product?
Best Answer12-09-2018 09:49 - edited 12-09-2018 09:50
Try changing the watch face from your fitbit app.
12-09-2018 11:33
12-09-2018 11:33
@BitAnime wrote:Try changing the watch face from your fitbit app.
I have tried but my app isn’t picking up my Fitbit 😭
Best Answer12-09-2018 12:22 - last edited on 07-06-2020 17:43 by LiliyaFitbit
The solution in my case was to reboot the Charge 3. I have to say that only my display was missing and the tracker was still syncing to the app.
Best Answer12-09-2018 14:51
12-09-2018 14:51
Same problem happened to me, charge was fine but screen would not turn on. I tried changing my clock display with my phone, then it worked again. Maybe try that, see if it helps. Good luck!
Best Answer12-09-2018 15:34
12-09-2018 15:34
Mine is doing the same thing, and even when i push the sode button to restart it, it stays blank. So i have no way to even restart my fitbit charge hr 3
Best Answer12-09-2018 21:32
12-09-2018 21:32
Best Answer12-10-2018 08:05
12-10-2018 08:05
Thanks for the tip worked on mine
Best Answer12-11-2018 02:09
12-11-2018 02:09
Hi my charge does not turn on screen it just vibrates. It is fully charged per my phone ap but wont show on device itself
Best Answer12-11-2018 03:50
12-11-2018 03:50
