10-10-2018
13:58
15:47
10-10-2018
13:58
15:47
Hi my new charge 3 is blank and when I charge it and try to restart it using the side button it just vibrates with a blank screen.
12-26-2018 10:03
12-26-2018 10:03
Best Answer12-26-2018 10:06
12-26-2018 10:06
12-26-2018 10:10
12-26-2018 10:10
Best Answer12-26-2018 10:14
12-26-2018 10:14
Best Answer12-26-2018 10:17
12-26-2018 10:17
Best Answer12-26-2018 10:21
12-26-2018 10:21
Best Answer12-31-2018 13:43
12-31-2018 13:43
Got mine today..... Won't do anything?!? Vibrates when plugged in...then vibrates when you touch the "button" but nothing? Brand new just out of the box!!!
Best Answer12-31-2018 13:46
12-31-2018 13:46
Best Answer12-31-2018 14:32
12-31-2018 14:32
Best Answer12-31-2018 14:42
12-31-2018 14:42
Best Answer12-31-2018 17:13
12-31-2018 17:13
Best Answer01-01-2019 07:19
01-01-2019 07:19
Best Answer01-01-2019 07:40
01-01-2019 07:40
Best Answer01-04-2019 06:45
01-04-2019 06:45
My Fitbit Charge 3 showed me a blank screen yesterday. No amount of pushing the side button opened the screen...it remained blank. I held the side button down for 10 seconds and the smiley face came on and then the screen worked perfectly...100% charged thru all this. This operation should be listed somewhere in the directions to using the Fitbit Charge 3.
Best Answer01-06-2019 19:28
01-06-2019 19:28
Happened the same, it sync'd with the app but nothing display. Called tech support at 7 pm PT, got recording the office is closed. It mentions on the website open till 9 pm PT.
Best Answer01-11-2019 10:07 - edited 01-17-2019 07:44
*edit* Fitbit sent me a new watch
Same happened to me as well. Black screen unless I hold the button down for 10 seconds and then a smiley face. I contacted Fitbit and have a case file open. Fitbit said they would email me back. That was 4 days ago and no email. It's really starting to tick me off!!!
Best Answer01-11-2019 10:30
01-11-2019 10:30
Best Answer01-11-2019 10:35
01-11-2019 10:35
01-11-2019 17:23
01-11-2019 17:23
it worked. thanks.
Best Answer01-15-2019 10:08
01-15-2019 10:08
I can confirm that changing the clock to a different one works as well. I used that method this morning.
Let me clarify things a little though for this method.
My charge 3 was able to synch fine and it was working normally. The only thing not working was the screen. I could tell this because the heart rate light was still blinking normally and I verified that it was synching with my phone. If your device does this then just change the clock to a different one and it should work again. Then you can change it back. The clock is an app and apparently the app is freezing.
When my first one died, not due to the battery btw, the heart rate sensor light was dead too. If that is the case then you need to try the restart method on the charger and if that doesn't work (it didn't for me) then either take it back to the store and replace it (my method) or call support and work with them to get a replacement. It's bricked. The one I have now has the December update and seems to be working fine otherwise. I got it on 12/15.
