10-31-2018
03:28
15:03
10-31-2018
03:28
15:03
I’ve had my Fitbit Charge 3 for two weeks, as I was walking out of work I noticed the screen was black after wanting to check what time it was, I thought the battery was dead so I connected through the USB cable and nothing happened except the flashing green light on the back, I tried the troubleshooting method where I gel the side button for 8 seconds and the screen remained black. I’m extremely frustrated because it’s basically new!! And I don’t understand what went wrong. If anyone one could help me with what to do next?
11-01-2018
06:47
06:41
11-01-2018
06:47
06:41
It's great to see you around @Maha_kha and @DIANARom welcome to the Community.
I appreciate all the efforts in trying to fix this issue. @Maha_kha upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution.
Now @DIANARom, if you haven't tried the restart process, please do the following:
Let me know the outcome. ![]()
10-31-2018 05:12
10-31-2018 05:12
I’m having the exact same issue and I don’t know what to do since it’s also new and it was a gift 😞
11-01-2018
06:47
06:41
11-01-2018
06:47
06:41
11-07-2018 08:17
11-07-2018 08:17
Hi AlejandraFitbit,
Thank you for the instructions. Your instructions worked to get my Fitbit going again.
Can you tell me why it went Blank in the first place? I don't want that to happen again.
Thank you,
Tessi
11-08-2018 06:37
11-08-2018 06:37
Thank you for this suggestion. It worked perfectly and now the update is downloading.
11-09-2018
03:14
08:11
11-09-2018
03:14
08:11
Hey @Tessi and @SunsetRunner, a warm welcome to the Community.
I am glad to hear that the instructions provided worked and that your trackers are working properly now. If there is anything else we can do for you, do not hesitate to post it.
Now about your inquiry @Tessi, we are not sure what might have caused this, but we would expect this to be a one glitch and I would ask you to keep an eye on your watch, and in the case this happens again, please let me know and I will be glad to further investigate.
Keep the stepping up! ![]()
11-13-2018 11:26
11-13-2018 11:26
I am having the same problem. Just a little while ago my Fitbit 3 locked up and won't respond. I tried your re- boot instructions but it is still non responsive. I have had the product about 4 weeks. Any other ideas?
Thanks
12-19-2018 05:17
12-19-2018 05:17
Have you received any response? I had the same problem and was able to restart as per instructions after a few tries. Frustrating...
01-16-2019 04:42
01-16-2019 04:42
same here, flashing in back, screen unresponsive even after putting on the charger, no battery picture, nothing...
01-16-2019 09:19
01-16-2019 09:19
Hi, I am having the same issue. I've tried the troubleshooting instructions you explained however it didnt work. Any other suggestions?
01-17-2019 07:30
01-17-2019 07:30
Just happened to my fitbit. I changed the clock face and it synced it and started working. I switched back to original face after sync.
01-17-2019 08:01
01-17-2019 08:01
Y’all guessing. I’ve had same problem with my Charge 3 two times in a month. The watch was a gift October 2018. The first time it happened, around mid Dec 2018, of course I performed the reset process first, it did NOTHING. By chance I happened to read a message that the user went into phone app, changing or selecting a different watch face selection. I tried it, and it worked. Well, it happened again yesterday, 1/16/2019, I noticed the blank screen while I was reading, though the watch is and was syncing with my iPhone properly I, once again, first went in to the phone app, selecting a different watch face. It worked. Why? This is ridiculous. Fix the glitch please.
01-17-2019 08:02
01-17-2019 08:02
Try selecting a different watch face in the app.
01-19-2019 10:05
01-19-2019 10:05
I’m having that exact same problem it lights up still, but the display stays black no matter what.
01-19-2019 11:46
01-19-2019 11:46
01-19-2019 13:25
01-19-2019 13:25
Best Answer01-24-2019 17:51
01-24-2019 17:51
I was having the same problem. I tried changing the clock and it worked
Best Answer01-26-2019 19:29
01-26-2019 19:29
My Fitbit charger 3 the screen is black what do I do?
01-27-2019 06:06
01-27-2019 06:06
01-27-2019 14:55
01-27-2019 14:55
I've had the same issue today, blank screen but the watch still vibrated whenever I pressed the button. Charging and trying to restart didn't work but changing the watch face has brought it back to life. Thanks for the suggestion!
