10-31-2018
03:28
15:03
10-31-2018
03:28
15:03
I’ve had my Fitbit Charge 3 for two weeks, as I was walking out of work I noticed the screen was black after wanting to check what time it was, I thought the battery was dead so I connected through the USB cable and nothing happened except the flashing green light on the back, I tried the troubleshooting method where I gel the side button for 8 seconds and the screen remained black. I’m extremely frustrated because it’s basically new!! And I don’t understand what went wrong. If anyone one could help me with what to do next?
02-05-2019 14:32
02-05-2019 14:32
You are a genius. This worked!
Best Answer02-20-2019 04:57
02-20-2019 04:57
My Fitbit does not show a battery when charging unit is attached. I held the side button for 8 seconds and I received a flat line twice...then held again and saw a smiley face but my watch continues to be blank. Help!!
02-20-2019 09:31
02-20-2019 09:31
02-20-2019 13:09
02-20-2019 13:09
This worked. Thank you!
Best Answer02-21-2019 05:19
02-21-2019 05:19
Hello everyone, So I have had the same problem mentioned.
Problem: The watch would still vibrate, and it would still record my steps and data, but the screen wouldn't turn on. Even after charging it completely and resetting it, there was no difference.
Solution: I went into the Fitbit app and changed the clock face, the Fitbit synced and now the display works again. Hope this helped.
03-02-2019 08:53
03-02-2019 08:53
I was having this issue today with my charge 3 and changing the clock face brought it back to life again. YAY.
Best Answer03-02-2019 08:58
03-02-2019 08:58
Best Answer03-09-2019 13:20
03-09-2019 13:20
This worked! Thank you!
Best Answer03-09-2019 13:36
03-09-2019 13:36
Best Answer03-11-2019 04:53
03-11-2019 04:53
I had this issue. I noticed mine was only displaying the time and so I tried restarting it and it will now display nothing.
03-11-2019 05:12
03-11-2019 05:12
This is the solution that has worked for many of us.
Best Answer03-11-2019 05:42
03-11-2019 05:42
Best Answer03-11-2019 05:48
03-11-2019 05:48
Best Answer03-11-2019 09:33
03-11-2019 09:33
No. Because I tried restarting it, but the screen won't come on at all is the problem. It stays black.
03-11-2019 12:42
03-11-2019 12:42
Best Answer03-15-2019 01:35
03-15-2019 01:35
After following all the steps my fitbit still doesn't light up. I pressed the button for 8 seconds, the smiley face comes but it still won't light up. I tried changing clock face in the App but it doesn't sync with fitbit. Screen stays black. Please help. Thank you!!
03-15-2019 04:21
03-15-2019 04:21
I just changed the clock face on the app and the screen came back. I then changed it back to the one I wanted and it's still working.
Best Answer03-15-2019 05:43
03-15-2019 05:43
I changed the clock face on the app but after that it is unable to sync with my Fitbit. App cannot find my Fitbit. It vibrates, I see smiley face and everything but won't light up and can't sync with my app.
Best Answer03-15-2019 16:51
03-15-2019 16:51
Best Answer03-15-2019 17:20
03-15-2019 17:20
I had the same thing just happen with my Charge 3!😡
