03-09-2021
23:31
18:27
EdsonFitbit
03-09-2021
23:31
18:27
EdsonFitbit
I have tried both settings: the standard which should calculate the stride length based on the height - it is wrong and massively overestimates walked distance. Then I tried to set my own data and it should be very simple: you walk a know distance, check how many steps you did, divide distances by steps and you get the stride length. I set it. And yet Fitbit still massively overestimates the distance. Now, what I do not get is: how can it be so difficult to multiply the stride length set in the app by the steps so as to get a better estimate of the walked distance? Thanks
03-10-2021
04:20
03:43
03-10-2021
04:20
03:43
Welcome to the Community, @Lørenzø.
Thanks for the information provided. Fitbit devices calculate distance based on the device’s accelerometer data and stride length setting.
Default stride length is based on your height and gender. If available, Fitbit devices use GPS data to calculate more precise distances.When you sync your device, our algorithm interprets the data from the device, and you see your distance traveled in the Fitbit app.
Note that when you track an exercise with GPS, both GPS and accelerometer data are used to calculate the distance shown in the Fitbit app. For more information about accuracy, check the article: How accurate are Fitbit devices?.
Have a good day!
03-10-2021 04:27
03-10-2021 04:27
03-17-2021
18:26
03:42
03-17-2021
18:26
03:42
Thanks for your response @Lørenzø.
To try to resolve the issue I would recommend restarting your Fitbit device by following these instructions.
In addition, you can set up your Tracker as a replacement device:
Whether this doesn't help, please let me know if you are you experiencing the same problem when tracking your runs?
See you around.
