08-08-2021
17:09
04:04
WilsonFitbit
08-08-2021
17:09
04:04
WilsonFitbit
I have a Fitbit Charge 3 and haven't worn it for a while. I managed to be able to sync it but it does not have the correct time.. no time at all how do I set my Fitbit
Moderator edit: subject for clarity/label/format
08-08-2021 17:35
08-08-2021 17:35
Fitbit gets time from watch when syncs; that's the only way.
08-08-2021 19:03
08-08-2021 19:03
Hi @Dodejo you say the time is incorrect, then go on to say that it has no time at all.. What do you mean by no time at all?
Is there a screen that shows a clock?
Have you tried setting up the Charge 3?
BTW I've moved your Charge 3 question into the Other Charge models board.
08-09-2021 04:08
08-09-2021 04:08
Hello @Dodejo. It's great to see you around! @JohnnyRow, @Rich_Laue Nice to see you around and thanks for your great input!
@Dodejo Thank you for the information. At this time, I'd like to let you know that the time on your Charge 3 should be fixed after syncing. If this is not the case, I'd recommend making sure that the time zone setting in the Fitbit app is correct by following the instructions in this help article: How do I change the time on my Fitbit device?
In addition, take into consideration that you can change the clock face on your Charge 3 by following these steps: How do I change the clock face on my Fitbit device?
Hope this helps.
