03-14-2019
17:15
11:22
03-14-2019
17:15
11:22
It receives texts but doesn’t vibrate when they come in. How can I set this up?
03-15-2019 05:33
03-15-2019 05:33
Welcome on board @Maves, it's nice to see a new member around! While reading your post I was wondering if by any chance you turned on the Do Not Disturb, Quiet hours, or Driving mode setting on your phone? Fitbit Charge 3 receives notifications, but your device won’t alert you. Swipe down to see your notifications.
If paired to an Android phone, your Fitbit watch or tracker can alert you to notifications at any time:
If your Charge 3 is still not vibrating after taking that into consideration, I'd recommend restarting your device by following these steps.
Hope that helps, keep me in the loop!
03-15-2019 07:16
03-15-2019 07:16
03-15-2019 13:01 - edited 03-15-2019 13:02
Hi @Maves! Thanks for getting back and for reviewing the steps provided above.
By any chance, have you seen if the vibration of your alarms work? If your device didn't alert you, make sure you successfully set an alarm. For more information, see How do I manage alarms on my Fitbit device?
Your Fitbit device vibrates to alert you at various times, including if you set an alarm, when you hit your step goal, or if you haven’t met your hourly activity goal.
If you correctly set the alarm or aren’t receiving other alerts, test your device’s vibration motor by connecting the device to the charging cable. For more information, see How do I charge my Fitbit device?
If everything works except for the notifications, I'd recommend setting up your notifications again:
Hope this helps, let me know the outcome!
03-15-2019 17:34
03-15-2019 17:34
03-18-2019 08:51
03-18-2019 08:51
Awesome news @Maves! I'm so glad to hear that your notifications are working fine after turning off your phone.
Please don't hesitate to let me know if there's anything else I may do to assist.
06-25-2019 10:33
06-25-2019 10:33
Same here
08-03-2019 09:13
08-03-2019 09:13
I'm having the same problem with my Charge 3 unfortunately. The device vibrates with the daily, hourly reminders to move and also when calendar events occur but the text message and phone call notifications are sketchy and inconsistent. Regularly having to resync device to app, power off phone check settings and reset the device. Any suggestions?
09-26-2019 10:41
09-26-2019 10:41
I'm having the same problem as Kim_CLE
11-01-2019 08:13
11-01-2019 08:13
My Flex2 is vibrating for phone calls but not incoming text messages. I have tried resetting it, deleting the device and adding it back, turning off the phone, adjusting the settings.....nothing seems to be helping.
11-08-2019 20:00
11-08-2019 20:00
I am also having this problem. I had problems with lines and I was sent a replacement and now I have this issue. How can this be fixed. Very upset. Conatantly having to restart my phone or redo my app is ridiculous.
12-15-2019 10:29
12-15-2019 10:29
my do not disturb was turned on, turned this off and it solved the problem
12-26-2019 12:27
12-26-2019 12:27
I have done all of these steps and my Charge 3 still won’t vibrate on calls and texts. My silent alarm goes off like it is supposed to. So I know the vibration is working and that it is paired with my phone. Is there another solution?
12-29-2019 12:11
12-29-2019 12:11
I went into the Fitbit app then to notification and turned off the messages then turned it back on. Vibration now works again.
12-30-2019 05:41
12-30-2019 05:41
I tried that and it still doesn’t work. 😕
12-30-2019 08:55
12-30-2019 08:55
And you restarted phone and fit bit?
12-31-2019 06:16
12-31-2019 06:16
02-12-2020 17:59
02-12-2020 17:59
I have this issue too. I've tried all the issues cited in this thread and it still doesn't vibrate for texts. I get airline and lyft notifications. just not call/texts. I have an iPhone XS
04-19-2020 08:41
04-19-2020 08:41
Has same issue of text & call notifications not vibrating when received on charge 3 since last iphone IOS update; tried turning off/on phone multiple times which didn’t work. Went to this forum & looked at settings - not on do not disturb mode. But I always have my phone on silent so I turned that off; notification vibrations started working. Still was frustrated bc it seemed I would be unable to get vibration alerts if phone is on silent. Then saw this post (turning off & on messages in fitbit app notifications) so I turned off msgs, restarted phone (just in case) then turned notification - msgs back on while phone on silent and all is good. Thanks!!!
08-20-2020 14:28
08-20-2020 14:28
Ever since my iPhone did an update a while ago, I do not get notifications on my fitbit for text messages. I get a vibration for phone calls and alarms but nothing for text messages. I have the alert turned on and I have taken the device off and reinstalled it but it still does not work. My iPhone has had an update since and it still does not work. Is anyone else having the same problem? When I first bought it, it worked but stopped since the first update. I have had two updates since then thinking it would fix the problem but it has not.
