12-21-2018
12:27
14:31
12-21-2018
12:27
14:31
After updating my Charge 3 with the latest software, my step count is counting two steps for every one, as well as the floors climbed. It is showing me reaching my step goals way earlier than I should, and I haven’t changed my exercise routine since the update.
12-23-2018
04:05
06:28
12-23-2018
04:05
06:28
Thanks for the participation in the Community @sbs1.
If your tracker is doubling your information, I recommend restarting it by doing the following:
I hope this helps, let me know the outcome.
05-22-2019 05:13 - edited 05-22-2019 05:14
Brand new Charge 3 bought it 5 days ago. Same problem. Have done this instructed restart. Have it set to non-dominant arm. Adjust the stride length and it's STILL super-inaccurate. Counted 12 steps as I put it on this morning. Then doubled my walk distance and steps this morning. With 1200 STEP before I got out of bed; 0 minutes of activity.
With the inaccuracy happening BEFORE I even put it on, this seems like a device issue.... Not a setting issue..
This makes me sad. And frustrated. I've owned two Fitbits in the past and had a bit of an issue with one before adjusting the arm placement. Then no problems after that...
Already read a bunch of forum posts with similar problems and have yet to see an acceptable resolution.
And now I have to deal with returning this thing after spending $150. Ridiculous.
05-22-2019 05:35
05-22-2019 05:35
Same issue since the update. I have restarted, deleted and reinstalled both device and app...still counting 20 flights when I haven't done ONE! So sad because I am outside the return window.
06-10-2019 15:25
06-10-2019 15:25
My Charge 3 fitbit just started doubling all my steps, floors and calories. I just rebooted it so I'll see if that helps, but I have to say I'm very disappointed. Not sure what I can believe.
11-25-2019 09:49
11-25-2019 09:49
Mine has been doubling steps since I got it; I have tried everything except resetting the app. Will do that now! Very frustrating!!!!
03-10-2020 16:54
03-10-2020 16:54
Did not work for me....I realize the original post is 2 years old, but felt it applied to my fitbit problem...
03-10-2020 17:03
03-10-2020 17:03
Didnt work for me either. I should be a super model by now according to all the flights of stairs it says I climbed!
06-02-2020 11:00
06-02-2020 11:00
Yep, same here. This is just starting to happen to me: doubling the step count and then randomly going back to the right number.
06-09-2020 21:12
06-09-2020 21:12
I have tried this several times.. It does not work.
06-09-2020 21:15
06-09-2020 21:15
this is exactly what is happening to me... did you find a solution?
06-09-2020 21:34 - last edited on 07-02-2020 12:36 by LiliyaFitbit
It stopped happening, so I’m hopeful that the gremlins just went away. But I didn’t do anything 😐
08-01-2020 08:48
08-01-2020 08:48
This just started happening to me also within the last few days. I've had it since April and this is the first time I've seen this problem.
04-22-2021 14:48
04-22-2021 14:48
I had the same problem. Following this advice immediately corrected the problem - reset my steps back to half of what was displayed on the fitbit watch. (The app was always showing the correct number.) I think it took a little longer than 8 seconds. Thank you.
04-26-2021
06:36
06:28
04-26-2021
06:36
06:28
Hello everyone. @JRicketts Welcome to the community forums!
@JRicketts I'm glad to know that the instructions helped to correct the inconvenience and thanks for the details you've shared.
See you around.
10-01-2022 07:23
10-01-2022 07:23
Same and now it’s 2022 and my charge 4 is doubling flights
