10-09-2018
22:20
15:47
10-09-2018
22:20
15:47
Hi, I have a new Charge 3 and I want to update my exercise shortcuts on my tracker to include yoga, hike, etc.
I have removed the ones I don’t want on the app but they will not sync. Every time I sync them it returns to the original exercise shortcuts that were preloaded onto the tracker and switches my options back on the app... any ideas?
05-16-2019 06:20
05-16-2019 06:20
05-17-2019 07:31
05-17-2019 07:31
Thank you, I too only had swim, Pilates, Pilates.... reboot worked!! 👍🏼😀
05-21-2019 06:40
05-21-2019 06:40
thanks...this worked for me!
05-23-2019 19:10
05-23-2019 19:10
I was also suddenly stuck with Run and 5 Pilates this solution worked for my Fitbit charge 3! Thank you!
06-27-2019 04:38
06-27-2019 04:38
This worked for me! Thanks so much. I had forgotten the reboot setting was there.
07-02-2019 21:54
07-02-2019 21:54
After reinstalling app several times, this worked!! Thank you!
07-09-2019 06:15
07-09-2019 06:15
Perfect thank you solved my problem no longer got Pilates 5 times
08-16-2019 07:03
08-16-2019 07:03
Thanks for that tip it’s fixed mine too!!! It was driving me crazy!!!
10-31-2019 12:05
10-31-2019 12:05
Hi, this is still an issue for my Fitbit and I’ve redownloaded the app, resynced the Fitbit and the shortcuts still aren’t syncing
01-02-2020 10:43
01-02-2020 10:43
I just followed the person that posted above you and the reset worked. Do the following:
On your device, go to Settings, About and then Reboot. All the shortcut exercises then synced properly.
Scroll left all the way to "settings"
click on settings and then scroll up until you get to "about" it is the last thing in the list.
click on about and scroll up until you see reboot device.
click reboot device and scroll up until you see the check mark and select the check.
This worked for me.
01-23-2020 19:35
01-23-2020 19:35
I had to update the app in the App Store as well as remove and reconnect the device to get them to sync.
05-01-2020 04:24
05-01-2020 04:24
Many thanks been trying to fix this all morning!
05-08-2020 20:18
05-08-2020 20:18
That worked...thank you
gosh I wish there was a basic instruction manual... all this shot is hidden until you do some major search...it’s very frustrating!
