09-24-2020
18:35
08:30
AndreaFitbit
09-24-2020
18:35
08:30
AndreaFitbit
I see in the Community that several folks have reported parts of this problem/these problems. My Charge 3 has all of these. About 2 1/2 weeks ago, the face dimmed and shortly after that it quit responding to the tap on the face for display. I can only get it to display at all by pushing the reset button. Most of the time, I cannot get the screen to advance by swiping. Understand that I'm out of warranty, since I ordered on an early-order offer in 2018. Any help for this or time to trash it and get something else? This is my 3rd FITBIT and liked it best, until now.
Moderator edit: format.
09-24-2020 19:01
09-24-2020 19:01
It sounds like you might be in Sleep Mode, making display dim and preventing display from wrist turn.
09-24-2020 19:01
09-24-2020 19:01
09-25-2020 06:49
09-25-2020 06:49
10-24-2020 12:51
10-24-2020 12:51
what is the fix, I can't seem to find it here?
10-24-2020 19:50
10-24-2020 19:50
11-21-2020 12:27
11-21-2020 12:27
This is my problem too, but how do you get it out of Sleep mode?
11-21-2020 12:58
11-21-2020 12:58
11-21-2020 13:23
11-21-2020 13:23
How do I get it out of sleep mode?
01-06-2021 02:46
01-06-2021 02:46
Swipe left to settings, then down to sleep mode. Tap that and you should see both "Sleep Mode" and "Schedule". Tap the top one (Sleep Mode), and that should take you from "on" to "off".
04-19-2021 21:07
04-19-2021 21:07
Thank you for explaining that! Mine was so dim that I couldn't really read it, so saying "tap the top one" saved the day! Thanks again!
04-17-2022 03:46
04-17-2022 03:46
Mine is the same, wont display when I move my wrist, only if I click the button and in display mode it will not let me adjust any of the settings eg: change from dim to normal or motion and button. If I go to Quiet modes the focus mode is switched on, Do not disturb is on but dim and won't change if pressed and Sleep mode is also on but dim and won't let me change it. Any ideas? Some where else mentions a reset but the only option that I see is the factory reset which will delete all data and settings so not sure if this is what I want?
04-17-2022 08:18
04-17-2022 08:18
04-17-2022 08:34
04-17-2022 08:34
I feel your pain VistaApps and all - My Charge 3 is having all the same issues as I have read in these forums. It's unfortunate that these devices aren't lasting longer - so wasteful and not environmentally friendly. I have bought 2 FitBits myself over the years and another 4 as gifts. How do you like the 5? I am considering it, but also looking at other brands.
04-17-2022 08:57
04-17-2022 08:57
04-17-2022 13:40
04-17-2022 13:40
I'm glad that worked for you. My problem is I can't even swipe to settings because my fitbit charge 3 is completely black.
04-17-2022 14:49
04-17-2022 14:49
It happened to mine and it the end I did a live chat with fitbit and after trying some things and nothing working I had to do a factory reset, settings - About Versa 3 - factory reset.
This of course wipes off any updates or apps you've added and you then have to add new device to the fitbit app.
What they didn't tell me was that you can no longer do this with windows 10 computer as not compatible, I had to go back onto the live chat to find this out and was told to use my phone fitbit app which worked fine. I'm just hoping this isn't a reoccurring problem as some others mentioned.
04-18-2022 07:06
04-18-2022 07:06
Can also get to Sleep Mode in Quick Settings, which is probably where it accidentally gets set to On. Press side button a few seconds to get to Quick Settings for most common settings.
