05-20-2020 08:57 - last edited on 09-16-2020 19:47 by
I've had my Charge 3 since December 2019, it never did work correctly. It has never registered a single stair taken even though I walk up 4-8 flights every day. The sleep tracking function recently started to fail too. I was sleeping through the night, but it started to track only about 1.5 hours or none at all. Last night I took it off to clean it and it went dark. I thought maybe the battery had suddenly died so I plugged it in. Checked on it 5 minutes later and it was so hot I could barely touch it!!! Thank the lord I checked on it. I had the Charge 2 for a couple years and loved it, so I thought the Charge 3 would be good... wrong! This one was junk!
09-14-2020
11:11
07:26
09-14-2020
11:11
07:26
Hey @StephRH, it's great to see you here.
I understand how are you feeling and appreciate the information provided. Your device may count less floors than you think it should for a variety of reasons. Not all flights are the same height or distance, so if the flight you climbed is less than 10 feet you may find that the device's floor count doesn't exactly match how many floors you climbed.
About the sleep, try the following:
Now about the hot to touch issue, are you still experiencing this?.
I hope to hear from you soon and let me know how the troubleshoot goes.
