05-28-2020 11:29 - last edited on 09-16-2020 19:33 by
My Fitbit charge3 froze. I followed the steps recommended to fix. it did not Get fixed. Please help
05-28-2020 11:56
05-28-2020 11:56
Hi, @Nnajand , a frozen Fitbit can almost always be fixed by giving it a restart, so when you say that you have followed the recommended steps, even if you mean you gave it a restart I would suggest tryng again.
Here is the procedure:
Sometimes you need to hold the button for considerably longer than 8 seconds, and sometimes it takes a couple of tries before this works.
Also do make sure that the charging point you choose is working (even if your frozen Fitbit doesn’t show you that it is). If it is not actually plugged in and charging the restart will never work.
I hope this helps. Good luck!
