12-09-2018
11:25
14:34
12-09-2018
11:25
14:34
My Charge 3 screen was frozen on the time screen. I can not get the unit to restart by pressing the side button for 8 seconds or even 15 seconds as suggested. Unit is less than 2 months old.
Any help out there?
Thanks
12-17-2018 03:01
12-17-2018 03:01
Like magic, but after many attempts all following instructions, the charge 3 restarted. That is good.
Sadly after contacting support and them determining that the situation needed to be advanced to a higher support level, I never heard from Fitbit. Does customer service exist?
12-09-2018 16:43
12-09-2018 16:43
I think you will need to contact Support (link in my signature) as the restarts arent happening. I must say though that I find mine rather hard to restart manually so have a few more tries at it making sure you are not diturbing the position of the tracker in the charging clip as you do it. I think mine loses contact when I use my thumb, but works better using a smaller finger.
Helen | Western Australia
12-09-2018 19:50
12-09-2018 19:50
Thanks for the comment and possible solution. Will try again. It has been on charge for about 24 hrs so must be fully charged.
12-10-2018
05:12
07:46
12-10-2018
05:12
07:46
It's great to see you around @jw22taylor and @NellyG thanks for the input.
I appreciate all the efforts in trying to fix this issue and would like to know if the instructions provided by our friend worked? Are you still having issues with your tracker's display?
Hope to hear from you soon.
12-17-2018 03:01
12-17-2018 03:01
12-19-2018
03:49
07:46
12-19-2018
03:49
07:46
Thanks for the information @jw22taylor.
I am glad to hear that your tracker is now working properly. Now about our support team, when did you contact them? Was it before posting here or after? Did they offer you a solution about this?
See you later.
12-19-2018 11:28
12-19-2018 11:28
"Yes, I contacted support before posting. They could not resolve the problem a said that they would raise the issue to a higher level. It looked like I would need to return the unit and I would receive instructions on the return. I have heard nothing from support since the long call with a failed resolution. All they asked me to do was repeat the standard actions. Plug in the unit. Push the button for 15 seconds. Repeat. Repeat. And Repeat! I can read. I can follow instructions as written on the Fitbit site!
I have no idea of why it resumed working properly. Clearly it was still tracking but the screen would not move to any other view. The unit or its software had, maybe still has, a glitch. Sadly Fitbit does not care about your quality control issues.
01-04-2019 09:21
01-04-2019 09:21
My charge 3 screen frozen on notifications. Has removed device from phone and readded but still frozen
01-04-2019 09:41
01-04-2019 09:41
Good luck! Hopefully magic will also work for you. Sadly there does not seem to be a rational solution.
Support will I’ll answer the phone but just guide you through what you have already done. They will then say they need to raise the issue to a higher level.
For me me they said they would get back to me but never did. Fortunately, like magic, my charge 3 started to work again.
03-05-2019 02:27
03-05-2019 02:27
The same thing has happened to me just this evening... did you ever fix it? I can't restart my Fitbit or anything.
03-05-2019 04:27
03-05-2019 04:27
04-16-2019 17:31
04-16-2019 17:31
I contacted them through email. Had three emails back and forth where I was told to redo what was in the written instructions, that I had done. Then they decided I needed to go higher up. Finally they sent me a new one. Now I am frozen again. I don't even want to contact them again. A lesson learned not to buy again.
09-09-2019 17:26
09-09-2019 17:26
Took about 4 tries to fix my frozen screen. Hooked up the charger and held the button for about 15 seconds.
I really want to enjoy my Charge 3, it would be a great device if they could just clear up some of the glitches and improve the accuracy of the mileage.
03-09-2020 08:22
03-09-2020 08:22
Side button not working, cannot turn it off or see main screen
03-09-2020 08:26
03-09-2020 08:26
Looks like many people have complained about this with no help
