Charge 3 frozen
ANSWERED
Went to charge my Fitbit, and it just stayed on the clock screen. It won't change with swiping, won't show the battery charging icon, nothing. Don't know how to reset the Charge 3, the instructions don't seem to work, or I'm on the wrong Fitbit.
Help.
38 REPLIES 38
I'd say email the Fitbit support team although this may mean a lot of toing
and froing.
Tried at least half a dozen times. How do I contact the support team please?
Moderator edit: format
Great Up and running again
Spoiler
Great. JaryM. Glad to hear that
Hi. Sorry just saw this message now. On the website there should be an e-mail link under "contact". E-mail your problem and they will reply. I think it is called fitbit- support. Maybe you have solved it by now.
Regards
1. This worked to reset the watch.
2. However after returning from a cycle ride immediately after the reset the watch would not sync with my phone. Assume this problem is something to do with the reset? Can anybody help. Thanks.
Have you tried restarting your phone
Mary
Yes that is always the tried and tested. The phone eventually woke up all
by itself! Thanks for the reply.
Thanks! It worked.
My Charge 3  I is frozen. I tried the best suggestion. I connected my charger to the tracker, held the start button for 8 seconds, but I never saw the smiley face and when I disconnected, it was still frozen.
Try holding down for 12 secs.
Try putting it on the charger and hold down the button for 12-13 seconds.  It works for me.
Yep It worked for me
Mary
Even though tracker is aligned with the button opening on the charging cable the tracker does not vibrate and I don't see a battery icon on your tracker’s display.
When my Charge 3 was completely dead I went on to the Fitbit site and used
chat to speak to them. They talked me through a few remedies but eventually
I was sent a replacement when nothing worked. When it was just frozen
putting it on charge and holding the button for 8 seconds worked.
Mary
Hi,
I think you should contact the community by email. Their details are on the
website.
Regards
mine is frozen on a text message and won't go anywhere, clipped to charger and held but won't reset.
Thanks!  You are so helpful!
Failed
