06-13-2019
08:37
10:58
06-13-2019
08:37
10:58
I just received a text and email that my charge 3 battery was low but the charge 3 showed 50 per cent and the app said medium. What level should the charge 3 be at when you recharge the watch
09-27-2019 06:19
09-27-2019 06:19
Best Answer09-27-2019 11:52 - edited 10-12-2024 12:36
Hi there @LaurenCat, welcome to the Community Forums. I usually charge my Fitbit devices when they reach 15% of battery level or at 20% as @Kennyfar has suggested. 😉
We recommend to charge your trackers via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. What may actually cause damage to the tracker's battery (either on a computer or a wall adapter) is the charging time, which if excessive over time may damage the battery and therefore cause quick battery drain or prevent the tracker from charging at all.
Tips to best charge Fitbit trackers are:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
For more detailed information, see: How do I charge my Fitbit device?
Let us know if you need further assistance.
Best Answer09-27-2019 22:44
09-27-2019 22:44
Thank you so much - great information.
Best Answer09-28-2019 10:47 - edited 10-12-2024 12:36
You're very welcome @LaurenCat. 😉
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Best Answer10-19-2019 00:20
10-19-2019 00:20
Best Answer02-24-2020 18:16
02-24-2020 18:16
Oops! I let mine go down. It lasted 10 days before it refused to sync. Now I know to watch out for it getting to 18%. I'll see how long it takes to run down to 18%.
Best Answer10-24-2022 01:52
10-24-2022 01:52
Over 3 years later and this is still a problem. Just bought a brand new Versa 4 and I get these alerts all the time, now it was at 53%. Every day it’s something new… spo2 not working, the pulse shows up with a 10 sec delay, the app keep referring me as a man…
