Charge 3 green light on and battery draining
I have turned heart rate monitor off and restarted my charge 3 several times. I’ve looked in previous threads and followed advice there. Problem remains though - green light is permanently on and battery draining within a few hours.
1 REPLY 1
If your Fitbit is losing battery, it's probably because a power-draining app or setting is turned on, like All-Day sync, constant notifications, or heartrate monitoring. You may also have too many apps running on your menu or you may be receiving silent alarms that are burning through your battery life
Regards,
Will
