02-23-2020
00:59
13:32
02-23-2020
00:59
13:32
Since a couple of days the green lights sensors on the back of the fitbit dont work.
I have restarted it many time following the instructions in other posts, eg:
I have also switched off the heart rate option in settings, restarted the device, turned it on, many times, but still the green lights dont come back. The other night, the fitbit also started vibrating continuously, and I had to take it off. I guess it stopped when the battery run out. The battery itself has a strange behaviour: it shows a value of charge when not connected to the cable charger, and as soon as I plug it, it shows a much higher value.
Thanks for the help
02-23-2020 10:28
02-23-2020 10:28
02-23-2020 10:28
Contact Customer Support.
Best Answer02-24-2020 06:51 - edited 08-23-2025 13:35
Hi there @giuseppeco, welcome to the Community Forums. Thanks for the details provided about your Charge 3's heart rate monitor, I appreciate you've taken the time to troubleshoot it prior to contacting us.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this. Please keep an eye on your inbox for updates on your case.
Thanks for your recommendation @SunsetRunner.
Let me know if there's anything else I may do to help you.
Best Answer09-01-2020 22:58
09-01-2020 22:58
Hi, I am experiencing the same issue described in this post and was hoping you could help me.
The heart rate monitor and green blinking light on the back of my device have stopped working. I have tried all of the above mentioned restart methods, as well as turning off the heart monitor feature and turning back on but have had no success getting things to work again.
I tried contacting support but keep getting directed back to this message board. Any help or advice you can give is greatly appreciated.
Thanks.
Best Answer09-02-2020 10:30
09-02-2020 10:30
I have contacted customer support. I suggest to do the same 🙂
Best Answer11-06-2020 09:21
11-06-2020 09:21
I’ve been experiencing this as well, I’ve tried everything but still nothing. No lights or heart beat. Please let me know what I need to do to fix this
