04-15-2019
10:06
11:10
04-15-2019
10:06
11:10
Grey lines on screen tried multiple resets to no avail. Charge 3 only 6 month old
04-15-2019 13:26 - edited 11-06-2023 04:43
Hello @HealthyJ, thanks for stopping by! Thanks for already restarting your Charge 3 in order to fix the grey lines on the screen. Nice way to go!
I was about to create a support case on your behalf, but I just saw that you contacted our Customer Support Team after posting here. Someone will be in touch with you soon. You're in good hands my friend.
Let me know if there's anything else I may do for you in the meantime. I'll be around!
04-16-2019 06:02
04-16-2019 06:02
Thanks for your assistance, customer service replied but still waiting for further reply as their troubleshooting did not resolve the issue
04-16-2019 06:11
04-16-2019 06:11
I am having the same issue and my charge 3 is only 4 months old. Restarting didn't help. Please advise.
04-16-2019 06:23
04-16-2019 06:23
Have tried several long restarts and still the grey vertical lines persists. Even tried changing clockfaces (long shot) but still issue. The Fitbit is tracking stats and syncs ok, but the touch screen sensitivity is very slow and now often unresponsive. Try contact customer services and if possible upload picture of your issue. They contacted me back with basic troubleshooting (didn’t help) hopefully they will email me back with a working solution or possible replacement device. Hope you get your issue resolved quickly 😎
04-18-2019 12:09
04-18-2019 12:09
my wife's fitbit charge 3 has the same symptoms. Gray background on the screen with faint vertical white lines. I have a charge 2 that has never had issues. Please help. I have tried all the reset processes listed and it does not help. thanks.
04-20-2019 02:35
04-20-2019 02:35
Hi I recommend that you contact the customer support team. They were most helpful.
04-20-2019 08:22
04-20-2019 08:22
I will try Customer Support, but wonder was the resolution was. Did your Fitbit return to normal, full-screen no vertical gray lines operation?
04-23-2019 06:28
04-23-2019 06:28
Unfortunately my Fitbit charge 3 still has the issue after trying all the troubleshooting. Customer services were very helpful and they sent out a replacement charge 3 which arrived 2 days later. Can’t fault the service too be honest. I have noticed that there seems to be a lot of users reporting this issue. I just hope no more issues with device and hopefully no reoccurring issues with grey lines.
02-29-2020 06:46
02-29-2020 06:46
I had the self-same problem. Tried the suggested re-starts on this site to no avail.
Contacted the Customer Services and after a couple of emails describing the problem, a new Charge 3 arrived within a week. Very impressive service.
02-29-2020 08:23
02-29-2020 08:23
