12-17-2022
14:27
04:39
12-17-2022
14:27
04:39
Brightness of screen issue resolved. For some time now have had multiple horizontal lines on screen getting worse. Pointless if I can't read the screen! I see multiple users having same problem. If you can't fix it I will look at other brands!
12-20-2022 04:40 - edited 08-15-2025 04:55
Hello there, @Lindarhasa. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Charge 3.
Please restart your Fitbit device as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope this helps.
Best Answer12-21-2022 09:39
12-21-2022 09:39
My first fitbit suffered from this issue and was replaced under warranty. The replacement is now the same {now out of warranty period} impossible to read the screen and non of the troubleshooting methods have helped. Looking at the forum this seems to be a common complaint and my view is that this fitbit model is not fit for purpose. I will not be buying another and like you, will look at other brands. A very disappointed customer!
