Charge 3 has lines across the screen
My Charge 3 has lines in the display making it hard to use. Please help.
Moderator edit: subject for clarity/format
3 REPLIES 3
Hello @Littlenucci, welcome to the community forums!
For screen inconveniences, I suggest you to review the following thread for tips and suggestions.
Hope this helps!
Wilson M. | Community Moderator, Fitbit.
I changed faces and I can read the clock. I also tried resetting it a couple of times, even the long one. I had Retro double stat then changed to the Retro and it is almost unusable. Please help.
I can't read the clock.
Moderator Edit: Merged posts
@Littlenucci, thank you for the troubleshooting steps you've tried!
As suggested on the thread above, if restarting doesn't work, the best way to get help is to contact our Support Team. You can click on the link provided in the thread or click here to get connected. Make sure to explain the situation and the steps you've followed, this way the support team can help you from there.
See you around.
