10-30-2018
07:09
15:03
10-30-2018
07:09
15:03
My Charge 3 has stopped vibrating for all notifications. I've checked all settings on my Fitbit and phone and all is set correctly but still no vibration!!!
unhappy 😢
10-08-2019 02:36
10-08-2019 02:36
My Charge three has automatically stopped vibrating! I have notifications and alarms show on the screen but with no buzz. I have restarted the device by holding down the button for eight seconds and the smile icon has appeared but with no effect. I have also tried rebooting the device and leaving it in charge but nothing’s working. I need help as I am now late to school because I have no alarms.
03:36
06:18
JuanJoFitbit
10-08-2019
03:36
06:18
JuanJoFitbit
Unfortunately this is getting bigger. It seems that Fitbit charge 3 has a unknown bug that stops and sometimes returns vibrating. Hope the fitbit’s engineers patch this in the new firmware release.
in my case, besides the vibrating on-off.. sometimes the clock gets late for 2 minutes for unknown reason...
Hi Sofia.
I think that you should contact support to get a new Charge 3.
If you are lucky to had bought yours in one of the authorized resellers and your watch is still under warranty..
This is very strange... The warranty should cover the device, no matter where you buy it...
Good luck!
Moderator edit: merged reply
Best Answer10-08-2019 04:08
10-08-2019 04:08
Hi Sofia.
Good luck!
Best Answer10-11-2019 21:10
10-11-2019 21:10
I contacted Fitbit support. They sent me a new one.
Best Answer10-16-2019 14:55
10-16-2019 14:55
Could you give address to get in touch with them direct please or email address
Best Answer10-19-2019 14:51
10-19-2019 14:51
I'm having the same problem with mine as well. I just contacted customer support and they're sending me a replacement since it's under warranty.
Best Answer10-19-2019 15:22
10-19-2019 15:22
This error seems to be the new normal on Charge 3.
Lucky you.. in my case, Fitbit won’t replace it since It was a gift from my wife in her last trip to Dubai. The Dubai’s mall is not an authorized seller... 😞
Best Answer10-19-2019 15:24
10-19-2019 15:24
Best Answer10-19-2019 15:41
10-19-2019 15:41
It's a year warranty. They ask where you bought it, when and what country. I went to contact us on the Fitbit website and emailed support. I think their email address is
Best Answer12-16-2019 07:15
12-16-2019 07:15
fitbit 3 has stopped vibrating. tried all resets and checked that vibrations are on.. but nothing. started 3 days ago. please advise.
Best Answer12-16-2019 08:05
12-16-2019 08:05
Best Answer12-16-2019 08:26
12-16-2019 08:26
only had the fitbit since june.. not impressed with it having issues already.
Best Answer12-16-2019 08:29
12-16-2019 08:29
12-16-2019 09:04
12-16-2019 09:04
thank you. it was purchased at bestbuy on june 2 ..
Best Answer12-16-2019 10:43
12-16-2019 10:43
Best Answer12-19-2019 12:12
12-19-2019 12:12
I have tried resetting mine several times and it still does not vibrate when I get a message. Vibrate when I get a call but not message. I have checked all settings also. Any ideas?
Best Answer12-19-2019 13:57
12-19-2019 13:57
really quite annoying.. not impressed at all .
Best Answer12-19-2019 14:55
12-19-2019 14:55
10:02
06:19
JuanJoFitbit
12-20-2019
10:02
06:19
JuanJoFitbit
It’s ever since the iPhone update mines not worked. I’ve tried everything 🙁
I’ve tried. I’ve tried everything, it’s since the iPhone update it’s fooked it up.
Best Answer12-20-2019 17:52
12-20-2019 17:52
My vibration worked fine until I got a new iPhone. Alarm works but not phone or text. I REALLY miss that feature. Is anyone from FITBIT monitoring this site? I HAD loved FITBIT--have had a some form of FITBIT since 2013. The answer might be the Apple Watch. FITBIT are you listening? Please answer!
