10-30-2018
07:09
15:03
10-30-2018
07:09
15:03
My Charge 3 has stopped vibrating for all notifications. I've checked all settings on my Fitbit and phone and all is set correctly but still no vibration!!!
unhappy 😢
12-20-2019 18:11
12-20-2019 18:11
It seems that Charge 3 has a bug that stop vibrating out of blue. Fitbit, now a Google company, has to pay attention to this very carefully. I’m moving away from a company that honors a warranty based only on authorized resellers and not in its product. Bye Fitbit.. hello Apple Watch.
Best Answer01-07-2020 13:39
01-07-2020 13:39
No vibration for texts, alarms, notifications and phone calls is the pits. Started after iOS 13.3 updated phone. Wish Apple and Fitbit would get fixed. Tried all the fixes, still no vibration. My Charge 3 isn’t that old.
Best Answer01-07-2020 23:17
01-07-2020 23:17
Mine is still not vibrating
Best Answer01-08-2020 03:24 - last edited on 02-09-2020 13:09 by LiliyaFitbit
Mine is working fine again now after I checked all my settings. They must
have reset themselves after the iPhone update.
I found the below very helpful and now working.
Good luck 😀
Kind Regards
Best Answer01-08-2020 04:03
01-08-2020 04:03
I found this very helpful and mine is now working. Since the iPhone update all the settings had changed themselves.
Best Answer01-08-2020 04:05
01-08-2020 04:05
Try the below as I had tried everything else myself and discovered the settings had all changed since the iPhone update. I hope it works for you 😀
Best Answer01-08-2020 07:19
01-08-2020 07:19
dont see previews .. i have iphone 11
Best Answer01-09-2020 09:05
01-09-2020 09:05
Best Answer02-08-2020 19:04 - edited 02-08-2020 19:06
I ran into that problem this week on my Charge 3, too. The vibration was completely off: it did not work when the button was pressed, nor in breathing exercises, nor in notifications, nor in alarms and coundown. I tried to restarting the device as support said, but it didn't work.
However, after the next actions, the vibration started to work again (don't forget to sync your data before continue):
1. on device: Settings - About - Clear User Data (hard reset process)
2. on app: Account (your portrait) - Charge 3 (device name) - Remove This (device name)
3. on phone: turn Bluetooth off and then turn it on
4. on app: Set Up a Device (and go trought the process of pairing as your first time)
5. then I run Timers - Countdown for 15s and only then the vibration started to work again (but not previously).
After this steps it works like before all the time.
02-10-2020 15:17
02-10-2020 15:17
still nothing.. just really disapointed with my fitbit 3 ...
Best Answer02-11-2020 10:10
02-11-2020 10:10
Best Answer02-11-2020 10:31
02-11-2020 10:31
mine was 6 months old.. still cant get it working right ... feel very disapointed with the fitbit ....
Best Answer02-15-2020 16:51 - edited 02-16-2020 11:57
In my case, I noticed that the vibration was working only sometimes, and that giving the fitbit a little whack made it temporarily work again, as if the vibrating mechanism were gummed up.
I then washed it in the sink with soap and water (since the Charge 3 is waterproof) and it seems to be working consistently since then. Could be just a coincidence, but I hope that helps you or someone else.
Best Answer02-16-2020 07:13
02-16-2020 07:13
Finally called fitbit, and they are sending me a replacement ... should have probably done that in june.
Best Answer03-09-2020 17:49
03-09-2020 17:49
I have the same problem on charge 3.
it stared doing this about 5 months after I had the watch.
03-10-2020 09:48
03-10-2020 09:48
Best Answer04-05-2020 17:56
04-05-2020 17:56
I can’t even reset mine. I push and hold the button and nothing happens.
Best Answer05-03-2020 05:32
05-03-2020 05:32
I am unable to get vibration on my fitbit 3 watch I have tried everything
Thanks pat
Best Answer05-03-2020 11:21
05-03-2020 11:21
Best Answer07-04-2020 06:34
07-04-2020 06:34
I did that and it didn’t work for me. What should I do?
