10-30-2018
07:09
15:03
10-30-2018
07:09
15:03
My Charge 3 has stopped vibrating for all notifications. I've checked all settings on my Fitbit and phone and all is set correctly but still no vibration!!!
unhappy 😢
07-04-2020 09:44
07-04-2020 09:44
07-04-2020 09:55
07-04-2020 09:55
My mom has a Fitbit charge 4 and she loves it. Mine is a charge 3 and its worked for the past few months. I think ill be getting a charge 4 next month! I just hope mine fixes by itself. 🤷:female_sign:
07-26-2020 13:09
07-26-2020 13:09
I can’t seem to get my charge 3 to vibrate with any of my notifications. It worked originally and then stopped working. I got it working last week for about 3 days and now nothing. I’ve checked all my settings and restarted it and still nothing works. So frustrating 😞
07-26-2020 17:07
07-26-2020 17:07
If it doesn’t vibrate when you plug it into the charger then the vibrator is defective. If it’s in the warranty period still, get in touch with Fitbit customer service and they will send you a replacement (after they walk you through a bunch of troubleshooting steps).
07-26-2020 17:12
07-26-2020 17:12
Thanks for the reply. I should have been a little more clear. It can still vibrate, alarms works, vibrates when I charge it, it just doesn’t vibrate for my notifications. It did once tonight, but that’s it. It’s so frustrating.
07-26-2020 18:10
07-26-2020 18:10
07-26-2020 18:13
07-26-2020 18:13
07-26-2020
18:42
05:09
JuanJoFitbit
07-26-2020
18:42
05:09
JuanJoFitbit
I did figure that out and the notifications are on. I’ve turned them off and back on multiple times and nothing 😞
This is just over a year old and I don’t think I’d buy another Fitbit product after this one.
Moderator edit: merged reply
07-27-2020
11:32
06:21
JuanJoFitbit
07-27-2020
11:32
06:21
JuanJoFitbit
My sentiments exactly.
Good luck, but it probably will not get any better.
Good luck, I'm sceptical of the Four.
Moderator edit: merged replies
08-24-2020 23:27
08-24-2020 23:27
09-13-2020 15:14
09-13-2020 15:14
I did all that, but still it doesn't work, no charging
09-14-2020
20:32
06:22
JuanJoFitbit
09-14-2020
20:32
06:22
JuanJoFitbit
Binky, I think it may have something to do with the new Charge 4. When the Charge 3 came out I had a Charge 2. Suddenly certain features stopped working on my Charge 2. After numerous calls to Fitbit I was told they disabled these features on the Charge 2 after consulting with customers but the features would be available on the new Charge 3!
Don’t bother. My daughter is having the same problem with her Charge 2!
Seems to be a Fitbit problem. My daughter is having the same issue with her Charge 2!
10-03-2020 04:19
10-03-2020 04:19
hi ! tried all these suggestions nothing works vibration isn't working.
10-06-2020 08:26
10-06-2020 08:26
Another thing to check is that the do not disturb is switched off on the device
10-06-2020 08:33
10-06-2020 08:33
10-06-2020 08:50
10-06-2020 08:50
I ditched my Fitbit and switched to an Apple Watch about 2 months ago. I haven’t looked back!
10-06-2020 10:17
10-06-2020 10:17
This did not work for me ☹️. After a software update. the screen dimmed. It was so dark I could barely see it. I missed logging two exercise routines. I had to reset the device and go back to Setting to brighten it. Now, the device will NOT vibrate when I hit 10,00 steps. It is set to "strong" This is device is way too much work. Wished I had done my research before I purchased this
10-07-2020 11:19
10-07-2020 11:19
Restarting my Charge 3 did not get the vibrations to work for the 10 minutes before the hour. A second restart and still not working. This really messes my steps if I haven’t got the number I want done.
10-24-2020 01:33
10-24-2020 01:33
Mine stopped vibrating too! Ug.
10-24-2020 05:34
10-24-2020 05:34
