10-30-2018
07:09
15:03
10-30-2018
07:09
15:03
My Charge 3 has stopped vibrating for all notifications. I've checked all settings on my Fitbit and phone and all is set correctly but still no vibration!!!
unhappy 😢
01-06-2021 08:41
01-06-2021 08:41
I'm having the same problem. Did the reset and saw the smiley face but still no vibrations and it's very frustrating.
01-06-2021 12:11
01-06-2021 12:11
Go to the settings on the Charge 3 itself, scroll down to sleep mode and press. Make sure both items are set to Off. This fixed my issue.
Best Answer02-06-2021 09:32
02-06-2021 09:32
Omg 😳my Fitbit quit vibrating since I replaced the band(charge 3) ive tried everything! Except your answer and I’ll be darned if it vibrates now🤷:female_sign:😳😳😳😳thank you ! Have no clue what or why . Just thankful 😍
02-06-2021 09:52
03-28-2021 09:29
03-28-2021 09:29
Very helpful. Thank you very much:-))
03-29-2021 06:52
03-29-2021 06:52
Hello everyone. @Gemgem82 Welcome to the community forums!
I'm glad to know that the instructions provided by @Jmneves99, have helped to resolve your inquiries.
See you around.
04-06-2021 21:21
04-06-2021 21:21
I tried the reset for 8 seconds and got the same results. Smiley face. No Vibrations. I found some settings (on the Charge 3, not in the app) that includes Exercise Alerts ON/OFF and Do Not disturb ON/OFF.
To find it, looking at the watch face, swipe left a few times until you see "settings." Tap that. Then swipe up until you see Do Not Disturb. Tap that.
If Do Not Disturb is OFF, then Exercise Alerts is greyed out. If it is ON, then you can turn on and off Exercise Alerts. At least, that what my Charge 3 does.
I don't know if you have to both do the reset, then look for the settings.
Best Answer04-07-2021 05:27
04-07-2021 05:27
Hello, I noticed 2 nights ago and again last night that my Fitbit Charge 3 did not vibrate at 10000 steps. Then, I realized it was also not vibrating when I pressed the side button. I have tried all of the suggestions offered: I restarted and got the smiley face, I went to settings and made sure sleep mode and schedule was off. I even tried the suggestion of going to ‘countdown’ and setting it for a second then double tapping (very random but worth a try) ... none of these worked! Any other suggestions or solutions would be welcome.
Best Answer04-07-2021 06:08
04-07-2021 06:08
Best Answer04-07-2021 06:25
04-07-2021 06:25
Best Answer04-07-2021 16:27
04-07-2021 16:27
Mine in the exact same. I've tried everything and won't vibrate anymore.
Best Answer04-07-2021 23:17
04-07-2021 23:17
And make sure don't disturb is off.
This fixed my problem.
Best Answer04-08-2021 07:04
04-08-2021 07:04
Thank you to those who replied with suggestions - I appreciate that people took the time to weight in. I have tried all the suggestions and unfortunately none work. The vibrate mode on my Charge 3 appears to no longer function. I have had it a couple years, maybe it is possible they just wear out? It’s frustrating but not the end of the world, obviously!
04-08-2021 07:30
04-08-2021 07:30
04-14-2021 17:05
04-14-2021 17:05
I tried everything also and nothing worked. The only thing that finally worked was the countdown timer trick but I had to tap it really hard to get it to vibrate. I bet that the vibrator is getting stuck and the combination of being activated and tapping at the same time frees it up.
04-14-2021 18:54 - edited 04-14-2021 18:55
@sav123 Thank you SO much!! I did the countdown trick again (after having done it about 30 times), but this time I tapped my Fitbit *really* hard and it worked! The Fitbit started to vibrate immediately. I had completely given up so I really appreciate you taking the time to weigh in!
Best Answer04-15-2021 00:17
04-15-2021 00:17
Have you tried this:
05-07-2021 17:01
05-07-2021 17:01
I have this same problem. Checked all settings. My charge 3 stopped vibrating after the firmware update. What can I do?
Thanks,
05-07-2021 23:50
05-07-2021 23:50
05-08-2021 04:34
05-08-2021 04:34
Hello everyone. @lindapk Welcome to the community forums. @erikannie Nice to see you around and thanks for your great input.
@lindapk Thank you for the detailed information and for the steps you've followed. If the instructions provided on the post above don't help, my best recommendation is that you please perform a long restart to your Charge 3. You can perform this, by following the steps below:
If that doesn't work, I recommend contacting our Support Team for further assistance. You can contact them through chat or over the phone and you can click here to get connected.
Make sure to explain the inconvenience and the troubleshooting steps you've performed, this way they can assist you from there.
Hope this helps.
