10-30-2018
07:09
15:03
10-30-2018
07:09
15:03
My Charge 3 has stopped vibrating for all notifications. I've checked all settings on my Fitbit and phone and all is set correctly but still no vibration!!!
unhappy 😢
02-11-2022 04:45
02-11-2022 04:45
Best Answer02-11-2022 05:33
02-11-2022 05:33
Thanks for the reply and siggestion...it doesn't work, I also tried the 8 second and 15 second reboot and vibration is always on in the app... I'm beginning to think that the vibrations mechanism is broken as no vibrations when it turns on / off either 🤔
Best Answer02-11-2022 05:48
02-11-2022 05:48
Best Answer02-11-2022 05:54
02-11-2022 05:54
Best Answer02-13-2022 06:40
02-13-2022 06:40
This didn’t work for me. It seems my Charge 3 quit vibrating after I did an upgrade.
Best Answer02-13-2022 06:44
02-13-2022 06:44
I tried restarting and still does not vibrate for notifications ( text, 10,000 steps, move at 10 to the hour) My charge 3 was recently updated, could that be part of the problem?
Best Answer02-13-2022 06:48
02-13-2022 06:48
I have the same issue, restarting did not restore vibration. The setting is on strong.
Best Answer02-13-2022 07:45
02-13-2022 07:45
Best Answer02-13-2022 15:28
02-13-2022 15:28
Hi,
Thank for this 🙂 I appreciate it - I've tried setting all that you suggested to off and have repeatedly set the timer to 1 second and no joy. I also pressed and held the button and reset the sleep and DND to off and still no vibrations. Was it the timer you had to set off 6 times? I've tried that too 😒 and nothing.
Take care,
Claire
Best Answer02-13-2022 15:29
02-13-2022 15:29
😒 sorry you're having the same issues - let me know if you find a fix. I'll post here if I do 🙂
Best Answer02-13-2022 15:30
02-13-2022 15:30
Thanks, I've tried that and it hasn't worked
Best Answer02-13-2022 15:46
02-13-2022 15:46
Best Answer04-13-2022 00:31
04-13-2022 00:31
I have the same problem
no vibration
is set to strong
done restart it didn’t work
04-13-2022 07:52
04-13-2022 07:52
What temporarily worked for me was to do a countdown timer and tap the face of the watch with my finger very hard at the end of the timer. Eventually that stopped working and I replaced with an Apple Watch.
Best Answer04-13-2022 08:10
04-13-2022 08:10
Best Answer04-13-2022 15:48
04-13-2022 15:48
