10-22-2018
12:38
15:03
10-22-2018
12:38
15:03
I think there's an actual issue with my fitbit but thought I'd post in here to see if anyone else was experiencing a similar issue.
I bought my charge 3 just under two weeks ago. Last Friday, I noticed my screen looked faded and had white lines running through it. I have tried to reset it three times as generally suggested with no such luck.
I haven't damaged it in any way and I've continued to wear it in the shower as I wasn't concerned due to it being waterproof. The day the faded screen/lines appeared was when the battery was very low - but that's the only thing I can think of and surely a low battery should'nt lead to this?
Anyone's help would be greatly appreciated before I have to take it back. I've tried to add a picture to this thread but can't for some reason.
Many Thanks
05-27-2020 01:27
05-27-2020 01:27
Mine was just out of warranty by 2 weeks. They offered me 50% off a different one or a brand new replacement. 3rd time lucky I guess. But I will say I have a Huawei band 4 Pro and its really good
05-27-2020 09:04
05-27-2020 09:04
05-27-2020 09:52
05-27-2020 09:52
I'd not say that but I'd already started complaining on twitter Facebook and threatened with the press and trading standards. I think it was just to shut me up
05-27-2020 10:06
05-27-2020 10:06
05-27-2020 10:16
05-27-2020 10:16
I'm still paying for mine as in put it on 12 months free credit I just expect something to last more than a few months
05-27-2020 10:19
05-27-2020 10:19
05-27-2020 10:49
05-27-2020 10:49
I think you should try pointing out that you are aware of at least 10 other cases on there replacement its happened to and hundreds of first timers and your responses have been unfair and unsatisfactory.
They tried telling me to do the reset that I'd already tried. I wasn't very polite either. They way you have been treated is not on especially in 30 minutes of finally dealing with me they had offered and dispatched a replacement
05-27-2020 11:15
05-27-2020 11:15
05-27-2020 14:19
05-27-2020 14:19
05-27-2020 15:24
05-27-2020 15:24
05-28-2020 14:19
05-28-2020 14:19
Hi,
I have this problem too. I have tried to reset the screen and followed all the instructions. It reboots the Fitbit but the white lines are still there.
is there something else I can try?
Thanks,
Niamh
05-28-2020 14:29
05-28-2020 14:29
05-28-2020 15:40
05-28-2020 15:40
05-28-2020 20:12
05-28-2020 20:12
05-29-2020 00:46
05-29-2020 00:46
You can push for a replacement but don't waste another penny on the charge 3.im just having my second replacement delivered they tried to fob me off but out of principle I didn't give in. I did find outting them on twitter helped. If u want any help give me a dm
05-29-2020 13:10
05-29-2020 13:10
mine is having the same problem and reset did not help.
05-29-2020 18:03
05-29-2020 18:03
06-04-2020 22:21
06-04-2020 22:21
My charge 3 did the same today. The battery was low and the white bars showed up. I charged it then I followed the instructions to reboot but the bars did not go away. Are there any other options to try to fix it?
06-04-2020 22:24
06-04-2020 22:24
Yes that is happening to me too. The screen does not respond well with the lines on it.
06-05-2020 07:46
06-05-2020 07:46
