10-22-2018
12:38
15:03
10-22-2018
12:38
15:03
I think there's an actual issue with my fitbit but thought I'd post in here to see if anyone else was experiencing a similar issue.
I bought my charge 3 just under two weeks ago. Last Friday, I noticed my screen looked faded and had white lines running through it. I have tried to reset it three times as generally suggested with no such luck.
I haven't damaged it in any way and I've continued to wear it in the shower as I wasn't concerned due to it being waterproof. The day the faded screen/lines appeared was when the battery was very low - but that's the only thing I can think of and surely a low battery should'nt lead to this?
Anyone's help would be greatly appreciated before I have to take it back. I've tried to add a picture to this thread but can't for some reason.
Many Thanks
03-13-2019 20:27
03-13-2019 20:27
My Charge 3 just started this today ...I have rebooted multiple times and the lines are still there . What can be done ??
03-13-2019 20:47
03-13-2019 20:47
I reached out to FitBit customer service after rebooting it several times and nothing worked. So they are replacing mine since it’s still under warranty.
03-20-2019 15:00
03-20-2019 15:00
Mine has started with this issue today and I purchased it at Christmas. Cleared the data and rebooted but the lines are still there.
03-21-2019 03:07
03-21-2019 03:07
I am having the same issue and have restarted. Can someone please let me know the next steps that I need to take ! I don’t want it to stay this way!! Thanks
03-21-2019 03:38
03-21-2019 03:38
03-21-2019 10:15
03-21-2019 10:15
Went on chat and all sorted - new charge 3 on the way - very easy and fab customer service 🙂
03-21-2019 10:16
03-21-2019 10:16
Contact Fitbit customer service, I used chat. Super easy and fab service, new charge 3 on the way to me
03-23-2019 10:40
03-23-2019 10:40
I have had my fitbit3 since December and noticed a few weeks ago that these lines were appearing. I checked on here to see if other people had had this problem and was surprised ar the number who had. I went in to Curry’s today where I bought it and I am getting a replacement on Monday....result!
03-23-2019 10:47
03-23-2019 10:47
Take it back to where you bought it they will replace it. I did this today no problem, I didn’t have my receipt but I showed them my bank account with the payment, I collect my replacement on Monday. It’s obviously a fault which is worrying I asked what to do if it happened again, they replied bring it back. I did wonder if it was anything to do with using it in the swimming baths I go 3 times a week but it is supposed to be waterproof.
03-27-2019 15:41
03-27-2019 15:41
I'm having the same issue. I've tried resetting with no luck.
03-27-2019 17:29
03-27-2019 17:29
Return it to where you bought it from they should replace it or give you your money back as it is faulty. I have my new one now. Good luck
03-27-2019 17:51
03-27-2019 17:51
I wondered the same thing about i being waterproof...i read on the replacement that it said to dry it really well after getting it wet.... makes me think it isnt .
03-27-2019 18:36
03-27-2019 18:36
Nope. Didn't work. Wish someone could explain why it has happened..
@JuanJoFitbit wrote:@Kellypops Thank you for participating in our Fitbit Community! I'm sorry to hear about the white lines you noticed on your Charge 3 screen. Thank you for taking the time to restart your tracker before contacting our forums. I'd like you to try one more workaround recommended for this issue:
- Sync their device.
- Open the Settings app on your device, tap "About". Finally, "Clear User Data".
After this, check out your tracker and see if the issue gets fixed.
Let me know how it goes!
03-28-2019 09:39
03-28-2019 09:39
03-31-2019 19:29
03-31-2019 19:29
Mine did the same thing today. I've had my charge for less than a month. My battery also went very low before it happened. Ive done nothing outside of the ordinary that would have damaged my fitbit.
03-31-2019 22:41
03-31-2019 22:41
Mine have this greyed out screen with white vertical lines.
Fitbit replaced it with a new device but it is a worry to see so many people with the same fault.
04-01-2019 03:53
04-01-2019 03:53
04-01-2019 03:57
04-01-2019 03:57
04-01-2019 05:11
04-01-2019 05:11
Hi I have issue with my fitbit having white lines across
Cleared user data and resetting but still dosen't work 😔
04-03-2019 21:32
04-03-2019 21:32
