08-25-2022 14:27
08-25-2022 14:27
Hi, my Charge 3 has just stopped monitoring my heart rate. I have read the previous posts and followed all advice about checking settings, tightening and loosening strap, and restarting the device (I have done this three times). Unfortunately there’s still a red light on the sensor where the green light should be. Is there any further advice for this please? I have only had this product since February this year. Thanks
10-10-2022 23:22
10-10-2022 23:22
Make sure your device is positioned correctly on your wrist: Tighten the band just enough so it doesn't slip on your wrist. Your device needs a solid contact with your arm to reliably track your heart rate. Heart-rate tracking may not work with certain accessory bands, especially if they're loose fitting.
Regards,
Will
