10-27-2018
09:20
15:03
10-27-2018
09:20
15:03
While fast walking (heart rate ~105), my Charge 3 shows suddenly 165, than 5 sec later 192 and even 203. After stoping the walk, it suddenly indicates 75 and than comes back to 103..... What can I do to solve that problem? Impossible to get a correct training mesure like this.
02-21-2020 00:56
02-21-2020 00:56
I too am having the same problem with my charge 3, which I didn't have with my charge 2. I've tried resets, switching the heat rate option on my teacker off and on again (resetting inbetween), swapping wrists, moving the location it's positioned on my wrist, loosening/tightening the strap. And still I have a heart rate of 140-160 while watching tv or lying in bed (neither of which were heart rate raising in any way!). My usual resting heart rate had been around 58.
I am having a replacement sent for my 2 month old charge 3 for a different problem (screen corruption) so I hope the heart rate problem doesn't happen with that. But after reading all these posts I'm not too hopeful.
Best Answer02-21-2020 04:08 - last edited on 02-23-2020 10:37 by LiliyaFitbit
I too had a replacement Charge 3 and the heart monitor was still
inaccurate. It's an issue with the Charge 3 software. I bought an Apple
Watch instead and will never own another Fitbit.
*May your day be filled with many blessings.*
02-21-2020 04:34 - edited 02-21-2020 04:35
Love how this is marked "solved/answered" and folks still having issues.
Most have moved on and dropped Fitbit. We did.
Fitbit devices especially the FB3 are more of a toy type gizmo, that will give you a very rough idea of what your HR is over a the past few days.
If you want much more accuracy and to use for training or working out, go with an Apple Watch. More expensive and yes you have to charge every 24 hours but it actually works the way Apple claims.
For more serious monitoring and week long battery life go with a Polar Vantage. About the same price of an Apple watch but made for athletes and people who are serious about true HR measurement during exercise.
02-21-2020 09:00
02-21-2020 09:00
02-22-2020 09:05
02-22-2020 09:05
Was running on treadmill 6mph and FB3 showed my HR was 113. When I changed out of my gym clothes FB showed a heart rate in the 130s. Makes no **ahem** sense.
02-22-2020 10:23
02-22-2020 10:23
Yes I think I'll have to change from Fitbit too. A pity really as I've always liked the presentation of the data on previous versions of Fitbit trackers. But completely useless if it's not accurate
Best Answer05-22-2020 11:28
05-22-2020 11:28
Fitbit also replaced my Charge 3. The new one had the same problem. At the beginning of a workout using one of there exercises (let's say "Workout") on the Charge3 ie. Just warming up my heart rate goes up to 150-160. I measured it myself (I can do it) it is 95-100. IF I don't specify an excercise the heart rate reading is 95-100. Something is wrong with the programmed excercises on the device.
Any ideas FITBIT?
Best Answer06-19-2020 12:33
06-19-2020 12:33
Charge 3 is completely bull**ahem**...and support not doing anything to solve this problem...Fitbit is going down...very disappointing...how can this be a solved problem..I see lots of people complained about this problem on charge 3, they are completely **ahem**ed themselve up! Good by Fitbit! Good luck to whoever still a royal fans to Fitbit! I used to be one of them, but not any more
06-19-2020 14:52
06-19-2020 14:52
Anyone besides myself wonder why Fitbit doesn't respond on this forum about the problem. I was riding a stationary bicycle today. Fitbit reported my heart rate was 200.
I'm 79 Years old. I should lave died of a heart attack. The machine showed HR was 97.
Best Answer06-19-2020 15:41
06-19-2020 15:41
Best Answer06-27-2020 21:11
06-27-2020 21:11
I have the Charge 3 and it has started acting up in the last month.
Basically, very inaccurate HR readings. Or no heart rate registering at all.
Tried doing everything the standard customer representatives advise - nothing has changed.
From reading other complaints, it seems these products have a 10 - 12 month lifecycle before they start acting up.
Time for the Apple Watch or a Garmin me thinks.
06-28-2020 10:27 - last edited on 07-16-2020 20:11 by LiliyaFitbit
My Charge 3 began inaccurate high pulse reading almost immediately. Especially when on one of there "activities". Fitbit replaced it and the problem still exists. Yesterday I was doing some light warm ups and it showed my purse rate at 200. I'm 79. Should have been having a heart attack.
Something is wrong with their algorithm and they don't seem to care or can't fix it.
Sent from my iPad
Best Answer06-28-2020 10:37
06-28-2020 10:37
Best Answer08-01-2020 07:59
08-01-2020 07:59
TL;DR try turning off the heart rate motoring, adjusting the screen brightness setting and then turning the heart rate motoring back on.
So I had been experiencing the same issues mentioned here and tried all of the usual things without success... my charge 3 was a present and so trying to return it was going to be difficult. After a couple of days I was getting desperate and recalled that the weirdness happened to coincide with me changing the screen brightness setting. I had found the auto brightness to be too bright so changed it to normal. Only realised that the HR monitoring was bonkers the next day when my sleep was not tracked.
In any case, after I realised the coincidence I turned the HR monitoring off, reverted to the auto brightness and then turned the HR monitoring back on. This work for like a few hours... only one setting left: dim... I repeated the process but changed to the dim setting and 10 days later it's still working!
Hopefully it's a permanent fix and maybe it can help others.
Best Answer08-01-2020 10:28 - last edited on 09-11-2020 20:17 by LiliyaFitbit
I've noticed that my heart rate is totally wrong, too high, when I'm doing warm up exercises. In these exercises I'm moving my arms from up to down and side to side, but with no extreme motion. Just slowly. HR goes from 85 to 130-150. To test this theory I put my arm (the one with the Fitbit) in a sling. Did the same exercises and my HR stayed in a reasonable range. So in my case is arm movements. If anyone has noticed Fitbit doesn't ever respond to our concerns.
Sent from my iPad
Best Answer08-06-2020 07:48
08-06-2020 07:48
Best Answer08-31-2020 16:33
08-31-2020 16:33
I love how this post is still going after 2+ years of people saying, “no it’s not resolved!”
My wife and I both have Charge 3’s and they’ve always been hit or miss on the heart rate accuracy. After lots of troubleshooting I’ve come to realize there’s simply a quality or design issue.
After the most recent firmware update both our trackers now run 20-30 bpm higher than actual (based on pulse rates). It’s fairly consistent too.
Fitbit would be better just to acknowledge the problem instead of blaming the customers.
I’ve seen them say using an off-brand band could cause it - which is pure snake oil. Given the variability of the human wrist, any comment about the band also is an admission that the tracker will only work with wrists of very specific circumferences and anything in between would simply not work - but I guess that doesn’t make for good marketing material.
The bottom line is these devices just don’t work reliably. Buying a newer model would only be rewarding a company for releasing an inferior product.
We’re switching to something else.
08-31-2020 19:13
08-31-2020 19:13
08-31-2020 19:18 - last edited on 09-11-2020 20:17 by LiliyaFitbit
Well, I agree that the Charge 3 shows 20-30 pulse rate too high. I determine this by comparing it with my Apple watch 4. As well as measuring my pluse on my wrist. Apple wins.
Sent from my iPad
09-11-2020 09:02
09-11-2020 09:02
Sunset Runner you got the apple watch and like it? Is it more accurate than charge 3? I will be driving and look down and my charge three will say 126, I know there is no way it is 126. Just curious as to what you think.
