12-13-2020
23:34
03:01
AlvaroFitbit
12-13-2020
23:34
03:01
AlvaroFitbit
My heart rate tracker has stopped working.It showed abnormally high readings even though I was relaxed.I rebooted my device and now it has stopped working.The green light at back does not flash anymore.I spent an hour in the pool last week wearing my charge4
12-14-2020
03:03
07:41
12-14-2020
03:03
07:41
@Sivenassen I hope you're doing well!
Let me help you with this and thank you for troubleshooting this issue. On you post you mentioned that you have a Charge 4 but you used the Charge 3 tag, could you confirm which one you have? I suggest you clean the back of your device with cotton and rubbing alcohol and restart it again. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
I look forward to your reply.
Best Answer12-14-2020 07:16
12-14-2020 07:16
07:31
07:41
12-14-2020
07:31
07:41
Not a problem @Sivenassen and thank you for clarifying this.
Just let me know once you have tried my suggestions and the results.
I look forward to your update.
Best Answer12-16-2020 01:20
12-16-2020 01:20
Hi AlvaroFitbit
I tried your suggestions.Did not work.My fit surcharge 3 won't recharge.I let it run down completely hoping it will restart when I recharge it.It is now dead.
I am not sure what to do next.I have had the Charge 3 for more than two years.Should I take it to Sportsmen Warehouse where I bought it and ask for help.
Regards
09:27
07:41
12-16-2020
09:27
07:41
@Sivenassen thank you for the update.
Since the issue persists I have created a ticket so our Support team can further assist you via email.
Let me know how it goes.
Best Answer12-17-2020 03:29
12-17-2020 03:29
12-17-2020
10:28
07:40
12-17-2020
10:28
07:40
@Sivenassen thank you for your reply.
Please do keep me up to date. Just notice that due to recent events affecting our operations, Support may need more than 7 business days to respond.
Best Answer12-17-2020 11:56
12-17-2020 11:56
