04-15-2020
16:55
15:27
04-15-2020
16:55
15:27
My Fitbit started registering what appears to be excessive steps, exercise & flights of stairs ... yet the miles are very low.
04-26-2020 08:08
04-26-2020 08:08
Welcome to the Community, @Dianamarie63.
I am sorry for the delay in response. For tips about improving accuracy, I recommend checking the help article: How accurate are Fitbit devices?.
Several things can affect the number of steps your Fitbit device records, including where you place the device, if you wear it on your dominant or non-dominant hand, and your stride length. If you're pushing a stroller or shopping cart, try putting your device in your pocket or use GPS to record your activity, if possible.
If it still seems like your device is undercounting or overcounting steps, try a step test. While you perform your step test, make sure you:
-Walk at a normal pace
-Don’t hold anything in your hands
-Put your arms down at your sides, swinging naturally
-Count 1 step for each foot
-To avoid getting an additional step when you bring your feet together, after you reach 100 steps:
Here’s the step test:
About the stairs, your device may give you credit for extra floors for a variety of reasons. Devices may track floors while doing everyday tasks such as opening doors, driving, or riding elevators or escalators, or from abrupt weather and atmospheric pressure changes Exposure to excess moisture can also result in extra floors.
Fitbit devices calculate distance based on the device’s accelerometer data and stride length setting. Default stride length is based on your height and gender. If available, Fitbit devices use GPS data to calculate more precise distances.When you sync your device, our algorithm interprets the data from the device, and you see your distance traveled in the Fitbit app.
Note that when you track an exercise with GPS, both GPS and accelerometer data are used to calculate the distance shown in the Fitbit app.
Let me know the outcome. 🙂
Best Answer04-28-2020 05:35
04-28-2020 05:35
What I don’t get is why are we getting these issues all of a sudden when we haven’t changed our habits. I don’t think this issue is resolved by the literature you gave us Fitbit moderator. Please look into your software and fix this , I assure you this is a court case waiting to happen if it’s a marketing gimmick to get people to upgrade by manipulating the older versions.
Best Answer05-18-2020 02:47
05-18-2020 02:47
I’m also having the same problem of the floors. The other day I registered 80 floors - while sitting next to my son’s hospital bed, didn’t leave the room with steady pressure and steady temperature. Not even allowed to open a window.
So disappointed. An expensive watch.
Best Answer05-18-2020 02:50
05-18-2020 02:50
