03-16-2024
08:44
08:51
03-16-2024
08:44
08:51
I’m traveling to Italy in May. Do I need a voltage converter for my Charge 3 Fitbit?
03-17-2024 15:16
03-17-2024 15:16
@Linphoto you'll need an adapter with the correct plug type for Italy. You don't need a converter though. If the charger that you use now says 110 - 240 V, it will be fine to use to charge your Fitbit and your phone overseas.
Amanda | Wyoming, USA
Pixel Watch 3, Inspire 3, Sense | Android
03-17-2024 08:53
03-17-2024 08:53
Hi there, @Linphoto. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post.
Fitbit devices require a USB port on your computer, a UL-certified USB charger, or other low-power device to charge.
Which mean you can charge your Charge 3 with any USB port as long as it is a UL/CE certified USB charger but not a fast charge adapter.
03-17-2024 15:16
03-17-2024 15:16
