Charge 3 is buzzing and won't turn off
  • it’s buzzing so much it moves across the table
  • wont turn off or reset
3 REPLIES 3
Welcome to the Fitbit Community, @ButtaB.
I am sorry to hear your Charge 3 is buzzing and won't turn off or reset. I am here to help. I recommend doing the following:
1. Confirm the steps to restart the tracker: How do I restart my Fitbit device?
2. Perform a long restart:
  • Connect the device to the charging cable.
  • While the device is plugged into the charging cable, press and hold the button down for 15 seconds.
  • The device turns on and shows a battery icon. Two vibrations occur: first a short vibration, then a medium vibration
  • The device turns off.
  • The device turns on and shows a progress bar and short vibrations occur. The progress bar completes. Note: A total of 7 short vibrations occur.
  • Remove the device from the charging cable. The device shuts down.
  • Important: Plug the device into the charging cable again.
Keep me posted on the outcome.
I did the 15 second restart while on the charger and a battery icon came on. It says 1% however there is a line through the screen with battery icon?
Sent from my iPhone
Hi @ButtaB, thank you for your reply.
I appreciate your efforts and the additional details. I've sent your information to the Customer Support team so they can get in touch with you and provide further assistance. You should be getting a reply soon.
Let me know if you have any questions.
