04-11-2019
05:10
11:10
04-11-2019
05:10
11:10
All of a sudden the Fitbit keeps vibrating then the screen keeps switching between click face and the notification screen. Had to take it off. The charge is at 42% so it’s not battery life.
04-16-2020 11:57
04-16-2020 11:57
This happened to me too! my battery keeps on turn flat....i tried the methods mentioned in the thread but it doesn't help ....
Best Answer04-16-2020 12:10
04-16-2020 12:10
Bummer and I have not heard anything back. This is my second Fitbit and I've only had for 18 months so I have a feeling I'll be moving on to another brand 😞
Best Answer04-18-2020 11:43
04-18-2020 11:43
This happens to me too...its super annoying. Iv also tried all the plug in and restart options. Seems like this is a common fault with this charge 3! 😒
Best Answer04-19-2020 06:54
04-19-2020 06:54
It’s a shame...still no response and since this is my second Fitbit that has died guess I need to find another brand.
Best Answer04-19-2020 07:41
04-19-2020 07:41
Best Answer04-19-2020 12:55
04-19-2020 12:55
My Fitbit Charge 3 is doing this exact thing. Everything was fine until yesterday when it started vibrating constantly and switching between notification screen and clock face.
Best Answer04-19-2020 15:41
04-19-2020 15:41
Hi mine does this and I have tried re setting as per the instructions from fitbit and I have changed the clock face a few times. I think I am out of warranty now? Can this be sorted? Sam
Best Answer04-20-2020 01:13
04-20-2020 01:13
Best Answer04-23-2020 13:17
04-23-2020 13:17
My phone has the same issue after being restarted. Notifications are off. Now tried the shut down and replug version descibed above and it still doesn't work.
Best Answer04-27-2020 08:03
04-27-2020 08:03
Best Answer04-27-2020 09:49
04-27-2020 09:49
I’m having the same issue. Just tried the instructions you gave the other users, but it still keeps vibrating and going back and forth between home screen and wake/notifications screen. It stopped reading my heart rate yesterday then started to do this. Did the same thing a couple months ago for a day or two, then went back to normal.
Best Answer04-28-2020 05:21
04-28-2020 05:21
ok..this is happening with my Charge 3 also now.....it just vibrates when I try to reset it...I have tried everything...this is now just a paper weight ....very frustrating as I can see that this is a problem that has been happening for awhile.... I need a resolution or a replacement.
Best Answer04-28-2020 05:35
04-28-2020 05:35
04-28-2020 07:19
04-28-2020 07:19
I am having the exact problem and this restart process has no effect. What next.? Any help you can provide would be greatly appreciated. Thank you for your time.
Jcoder
04-28-2020 07:23 - last edited on 06-05-2020 13:23 by LiliyaFitbit
I would try Customer support if your Fitbit is still in warranty. IF not I would just buy another make of fitness tracker as Fitbit is useless.
GOOD LUCK!
Best Answer04-28-2020 08:26
04-28-2020 08:26
I am out of warranty. What device would you recommend? I only want to track my heart rate and steps. If I could get blood pressure as well that would be great!
08:27
06:17
JuanJoFitbit
04-28-2020
08:27
06:17
JuanJoFitbit
Problem never resolved. Everyone keeps telling me to find a different tracker!
Moderator edit: merged reply
Best Answer04-28-2020 08:35
04-28-2020 08:35
Best Answer04-28-2020 08:40
04-28-2020 08:40
I requested help 2 weeks ago and still no response from Fitbit but they keep pushing me emails to buy new products. I'm about 6 months out of warranty wonder if that is the reason? I understand that businesses are a challenged right now but I'm sure most of their support team is remote and/or could be remote very easily. It's beyond disappointing and makes it worse that I see so many other customers with the same issue and no one has responded from Fitbit.
Anyone have any new ideas of how we might get some help?
Best Answer04-28-2020 08:43
04-28-2020 08:43
Maria....I assume you work for Fitbit Support? Have you seen how active this thread is without any response from Fitbit? Can you please help? This is so disappointing
