04-11-2019
05:10
11:10
04-11-2019
05:10
11:10
All of a sudden the Fitbit keeps vibrating then the screen keeps switching between click face and the notification screen. Had to take it off. The charge is at 42% so it’s not battery life.
08-06-2020 10:11
08-06-2020 10:11
This hasn't worked. My Fitbit is all barr dead atm. Not connecting to bluetooth now either
Best Answer08-06-2020 11:00
08-06-2020 11:00
Hi, I am also having this issue after having the Charge 3 for about only over a year. I had the Fitbit Flex (original) prior to this and that one lasted me several years (like 3-4 years), I upgraded just because I wanted a new one but not because the Flex stopped working. It seems like the Charge 3 with this issue is a fatal flaw as how many other people are also responding to this thread. Mine is vibrating at random moments, the screen is flashing on and off, the screen becomes unresponsive to my touch, seems to be clicking stuff on its own, and this happens even when it is connected to my computer charging. I noticed that a progress bar shows up on the Charge 3 when connected to the computer but it gets stuck and stays with that bar showing on the screen until I disconnect it. I tried the smiley face reboot option and also the reset (Swipe to the right until you get to About, scroll down, Clear User Data), but none of these fixed. I forgot the Bluetooth device from my iPhone, removed the device from my Fitbit app, and nothing works. I presume it dead.
Will try customer service to hope for a replacement but at this point I may go elsewhere and look at the Apple Watch, only issue is longevity.
Best Answer08-06-2020 13:47
08-06-2020 13:47
I used live chat. Posting mine back to them. Seems dead. Not connected to bluetooth... device not found. Nothing on screen. Button not working either now 🤬
Best Answer08-15-2020 16:42
08-15-2020 16:42
I sent my first one back for this reason(had it for about 6 months)
Got another for free under my warrantee. It started the same thing(vibrating and screen going crazy)
I put it out in the sun to see if some moisture got into it.
After a day in the sun, the problem went away.
All I can figure is the fitbit is not waterproof as advertised.
Maybe store the fitbit in a container of rice when charging to keep this problem away.
Also, don't wear it while washing your hands, swimming showering or anything else near water.
Best Answer08-16-2020 11:16 - edited 08-16-2020 11:18
I spoke with a support agent regarding this issue and they said that they could only offer a discount toward a new Fitbit product. (I asked if I could receive a replacement for this current tracker and the agent said that they could not; I told him that I had a previous issue with the original Fitbit Flex and it was replaced after about two years of use, but he said they are following their 1 year warranty policy strictly now. I bought the Fitbit Charge 3 in April 2019 and it stopped working in July 2020. Sheesh.) It's unfortunate as this seems to be a noted issue with this particular model based on how many people replied to this thread. On to a new search for a reliable tracker with longevity. 😕
Best Answer08-16-2020 11:36
08-16-2020 11:36
Best Answer08-16-2020 11:39
08-16-2020 11:39
Best Answer08-16-2020 11:41
08-16-2020 11:41
Best Answer08-16-2020 11:44
08-16-2020 11:44
Best Answer08-16-2020 11:46
08-16-2020 11:46
Best Answer08-16-2020 11:48
08-16-2020 11:48
Best Answer08-16-2020 11:50
08-16-2020 11:50
Best Answer08-16-2020 12:08
08-16-2020 12:08
Best Answer08-17-2020 09:22
08-17-2020 09:22
Ran into the same problem; constantly switches between screens and vibrates until the battery dies. I've had similar problems with other 'waterproof' devices. Eventually the seals go and if any moisture gets in, it's locked in. My device is about 2 years old so past warranty.
FIX: I put it in a bag of rice for a week. Yes, it really does take this long and even longer depending on the relative humidity where you live.
It works fine now but I'll never let it get wet again which is a bit annoying because that was one of the selling features. And when it stopped working, it wasn't submerged. I had a shower with it on.
08-17-2020 09:54
08-17-2020 09:54
Best Answer08-17-2020 10:34
08-17-2020 10:34
Best Answer08-24-2020 12:55
08-24-2020 12:55
I am having this issue have tried all the reset suggested and now device has gone completely dead it was a Christmas present so still in warranty any ideas what to do now going walking break on Wednesday and was hoping to use the tracker then
Best Answer08-24-2020 13:35
08-24-2020 13:35
Best Answer08-24-2020 13:38
08-24-2020 13:38
Best Answer08-24-2020 19:12
08-24-2020 19:12
