12-20-2018
00:05
14:31
12-20-2018
00:05
14:31
I have literally just done the latest update on my charge 3 now I have nothing showing up on my screen. If I do a reset we see the happy smiley face (not mine), if I change the clock face you see the line saying it is being changed but apart from that nothing.
Is anybody else having this problem?
really annoyed
Larry
12-20-2018 09:38
12-20-2018 09:38
Did you try restarting it?
Best Answer12-20-2018 09:52
12-20-2018 09:52
Yep three times it shows the face but that’s it so simple remedy I’m sending it back & I’ll go back to my charge 2 which has never let me down. This is my second one & the first one went back as well so all in all will never buy a Fitbit product again.
12-20-2018 11:45
12-20-2018 11:45
Thanks for stopping by @Larryf666! Sorry to hear about the inconveniences you've been having with your Charge 3. Thanks switching to a different clock face and for restarting your tracker as @SunsetRunner suggested. ![]()
There have been some updates to the clock face features with this update. When using Mod Clock or Analog Stat you should be able to cycle through date and stats. Try tapping on the clock face to see all your stats.
Let me know the outcome, I'll be around!
12-20-2018 14:02
12-20-2018 14:02
What is the point of tapping on the watch face when the screen remains blank & won't show anything. As I said it's going back & I will never purchase a Fitbit again the Charge 3 has most definitely ruined my enjoyment of using to help with my fitness.
Apple watch is the way forward I think.
12-28-2018 19:09
12-28-2018 19:09
Sounds like you have the same issue as me and others. Chat with support online. They will go through a few steps and then send you a replacement. It seems that the update has bricked some devices. For me, I would reset and see the smiley face, but nothing else would happen and my phone could not see it.
Best Answer02-12-2019 13:19
02-12-2019 13:19
I purchased my Fit it charge 3 on 18/01/19 and today the display isn’t working. I have tried to hold down the button as suggested but that hasn’t worked. Does anyone have further suggestions please?
@Larryf666 wrote:I have literally just done the latest update on my charge 3 now I have nothing showing up on my screen. If I do a reset we see the happy smiley face (not mine), if I change the clock face you see the line saying it is being changed but apart from that nothing.
really annoyed
Larry
02-12-2019 14:11
02-12-2019 14:11
Sounds bricked. Mine did the same thing. Call support. They will replace your FitBit (after they torture you by making you do all the resets, etc. etc.).
02-13-2019 17:51
02-13-2019 17:51
My Charge 3 just quit displaying after only about 3 weeks. Customer service said they will replace it but it is taking over 12 days to get the new one. I loved the Charge 2 ( which I gave away ) but have little confidence in the new & "upgraded" Charge 3.
Time will tell.
02-14-2019 02:35
02-14-2019 02:35
02-14-2019 04:44
02-14-2019 04:44
Fitbit support did check the Charge 3. Fitbit support, from my experience, is one of the best support services. They were most helpful and arranged for a replacement within a few hours.
My issue is the "quality" of the Charge 3.
02-15-2019 10:55
02-15-2019 10:55
I’m now having the same issue! How do I reset charge 3 w/out a screen showing?
02-15-2019 11:13
02-15-2019 11:13
Try going to the Charge 3 icon on your phone. Change the clock face to another face and see if that works. I came across this quite by accident but now it's displaying correctly.
Before, when the screen was black, not even the charge % would show. Let me know if this works for you.
Fitbit will replace the Charge 3 but it takes forever for them to get the replacement to you.
Best Answer02-15-2019 11:16
02-15-2019 11:16
Best Answer02-15-2019 11:20
02-15-2019 11:20
Try changing the clock face - this worked for me. Let me know if that works for you. Doing a "reset" did not work for me but when I changed the clock face to another face, the Charge 3 works fine.
02-15-2019 12:41
02-15-2019 12:41
03-11-2019 15:53
03-11-2019 15:53
Thanks for this post. Worked!
Best Answer03-30-2019 08:15
03-30-2019 08:15
Thank you! Changing the clock face worked!
Best Answer03-30-2019 08:28
03-30-2019 08:28
Best Answer09-20-2020 06:11
09-20-2020 06:11
I have tried this troubleshooting method but I don't even get the smile icon on display after holding down the side button for 8 seconds. My Fitbit will track steps, sleep, etc. but there is a blank display. I even tried changing the clock face and there was no change, still a blank display. Ever since the firmware update, I have had this issue. Any other thoughts to try and get this fixed?
