05-08-2021
00:29
04:12
WilsonFitbit
05-08-2021
00:29
04:12
WilsonFitbit
My I pad is not syncing with fitbit
05-08-2021 00:45
05-08-2021 00:45
What usually works for me when I have syncing issues is to restart the tablet, restart the fitbit ( Help article: How do I restart my tracker? ), and "forget" the link to the fitbit in the tablet's bluetooth settings. If they don't work for you , then try Fitbit's troubleshooting guide at: Help article: Why won't my Fitbit device sync?
05-08-2021 02:49
05-08-2021 02:49
05-08-2021 04:16
05-08-2021 04:16
Hello @Bic59. It's great to see around! @SteveH I'm glad to see you around and thanks for your input!
I was able to see that information about your concern was provided in a previous post. If that was the answer you were looking for, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
See you around.
Best Answer05-08-2021 10:53
05-08-2021 10:53
Thanks for the helpful guidance.. Rebooting the Charge 3 solved the problem.
05-10-2021 05:24
05-10-2021 05:24
@randomi Thanks for your reply!
I'm glad to hear that restarting your Charge 3 resolved the inconvenience.
Have a great day!
