03-19-2019
19:20
11:22
03-19-2019
19:20
11:22
I've been using my Charge 3 for about two months now and noticed that often when I run, the GPS map accurately reflects my route, but the distance is quite a bit off. I tested this a few times by running the perimeter of Mile Square Park, a park so named because it's a square approximately 1 mile on each side (4 miles total).
Here are the conflicting data points (links to screenshots):
As you can see in #3 and #4, the route captured by my phone's GPS seems accurate; it goes around the perimeter of the park, with no gaps. But somehow the distance is approximately 0.6 to 0.7 miles less than what it should be, which suggests that Fitbit is interpreting the GPS data incorrectly. Any idea what's going on here?
05-02-2020 09:57
05-02-2020 09:57
05-08-2020 22:53
05-08-2020 22:53
Hi may I ask how you downgrade the apps ?
05-09-2020 06:06
05-09-2020 06:06
You just have to delete the app and then download a different version from
an app mirror. I can't give more information than that without violating the code of conduct for this forum (I tried and the message was not allowed). This is not a recommended Android
method and should be avoided if possible because it opens that phone up to
potential security vulnerabilities.
Since I downgraded there have been 2 app updates (3.19.2 and 3.20) that I
haven't tried, so I will have to reupdate and see if things have been been
fixed.
05-19-2020 05:17
05-19-2020 05:17
Just did a 7.4km walk map is accurate but fitbit distance shows 5.79km big difference, very annoying.
05-29-2020 13:40
05-29-2020 13:40
Any word if 3.21 release addressed this? I'd rather not have to buy another option but will should I need to.
05-29-2020 13:43
05-29-2020 13:43
05-29-2020 13:45
05-29-2020 13:45
Thanks for the update. I think based on the reading I've done recently, Fitbit has lost quite a few customers
05-29-2020 13:54
05-29-2020 13:54
For flatter terrains, 3.21 has been really good for me, but when I'm mixing in steeper sections everything goes out of wack. 3.17 was the most stable for me.
05-29-2020 14:04
05-29-2020 14:04
05-29-2020 14:05
05-29-2020 14:05
05-29-2020 14:08
05-29-2020 14:08
This is on Android, right? Go to the play store, click "My apps & games" and find where your fitbit app is. It will either have an update available or be up-to-date.
05-29-2020 14:19
05-29-2020 14:19
06-18-2020 12:38
06-18-2020 12:38
I run with my GPS connected and the map shown on my Fitbit app after my run is perfectly accurate. However, the distance is horrible. On Google maps, my run today was 4.6 km, on Fitbit it recorded 3.55 km with GPS connected. What is the issue here. This happens 99% of the time and it is negatively impacting my pace and my overall fitness score on the app.
06-18-2020 13:25
06-18-2020 13:25
I've tried adjusting stride length and it makes no difference. It's very frustrating
06-18-2020 13:33
06-18-2020 13:33
06-19-2020 02:36
06-19-2020 02:36
Hi I managed to solve my issue. Before the run I restart my Samsung S9 plus and make sure the phone power saver mode is not turn on. With this I am able to get quite accurate GPS distance. Cheers!
06-19-2020 02:40
06-19-2020 02:40
06-19-2020 05:36
06-19-2020 05:36
Ya this is the same issue I had. Goggle map is accurate but the distance for around 9 km run only show around 7.30 km.
06-27-2020 22:35
06-27-2020 22:35
Same issue with mine.
1 the connection was done before the run
2. I measured the length using Google maps built in tool + I measured with another app. They showed the same 1,7km for my short beginner run. However firbit told me 1,4. Even if drawing the line for my run close to correct.
Soo disappointing. My next watch is not a firbit....
11-30-2020 17:51
11-30-2020 17:51
Mine is off about 1.5 miles
