Charge 3 is stuck on DND
My charge 3 is in Do Not Disturb mode and I can't turn it off?  Also the screen wake is turned off and I can't turn it back on.  Any ideas?
1 REPLY 1
Hello @R127, welcome to the community forums!
If you can't turn off the DND setting, I recommend performing a restart by doing the steps here. For the Screen wake, you can't turn it on until the DND setting is disabled. If the inconvenience persists, I recommend visiting the following thread for updates.
Also, for more information about your device's screen, see How do I navigate my Fitbit device's screen?
Hope this helps!
Wilson M. | Community Moderator, Fitbit.
