12-19-2021
04:16
15:36
12-19-2021
04:16
15:36
So my fitbit charge 3 shows an error 001 after charging. The screen online become black after pressing the side button and it wont start anymore. When put back on charge it displays 001 again after some time. How can i fix this problem please?
12-20-2021 15:38 - edited 03-15-2024 11:51
Hi there, @Brieq. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Charge 3.
If you haven't done so, I'd recommend performing a long restart to your Charge 3, a long restart is different than the basic restart and you can complete it by following the instructions below:
If the issue persists, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
I've moved your post to Other Charge Trackers board for organization purposes.
11-16-2022 00:49
11-16-2022 00:49
Please restart your tracker and if this process doesn't work, perform a long restart by doing the following: Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button.
Regards,
Will
