04-19-2020
04:02
13:02
04-19-2020
04:02
13:02
My Charge3 stopped 2 days ago. This was sudden: I wanted to see the time and pressed the side button, but there was no response (no vibration, black display).
I tried rebooting using the charger but, at first, it didn't work. After a few attempts removing and replacing in the charger, I succeeded but, since the rebooting drained the battery (36% to 2%), I let it charge.
After charging, it seemed to work, so I put it back on and continued my work around the house (no exercise, just cooking, doing dishes, etc). A few hours later I realized that I had more than 2 hours' worth of active minutes. I later noticed that my heart rate was in the cardio zone even though I wasn't doing and hadn't been doing anything much, just sitting around. I compared it with the heartrate measured by my blood pressure meter and there was a big difference.
For the past 2 days, the heartrate is very high, whenever I check, and I keep getting enormous amounts of active minutes, even in my sleep.
One last thing: the heartrate light on the back of the tracker never stops, even if I take the tracker off for a few hours. I really don't know how to troubleshoot this anymore. I have lost count of how many times I tried to reboot /reset.
Any suggestions?
Update: The issue has become random. Some days, after restarting the device, it seems to be OK, others not. The battery only lasts 1 day now. I have to recharge every morning. I have restarted using the suggestion below but the high heart-rate/calorie count still appears randomly.
04-30-2020 08:24
04-30-2020 08:24
Hello @A-M_E, welcome to the Community Forums. We apologize for the late response, due to recent events affecting our operations, we're taking longer to respond.
I'm sorry to hear that your heart rate started showing very high after the restart you performed, thanks for all the details provided. I'm here to help you. 🙂
As a first approach, I'd like you to perform the following steps below for this situation:
Give this a go and let me know if the heart rates is still showing high and the green lights keeps non-stop flashing, I'll be around.
Best Answer04-30-2020 11:57
04-30-2020 11:57
I have had the same problem with the heart rate and did the same check with my blood pressure monitor which gives pulse and with my NordicTrack. I have followed the above instructions and hope they work. I also am having other problems. Sleep is not tracking properly, showing less that I am getting. And I switch between a Charge 2 and Charge 3—this week when syncing the steps on my iPhone the steps from the 2 were deleted from the total. Also, the mileage for my steps has been changing. It has been the same for years. What up?
Best Answer05-21-2020 11:14
05-21-2020 11:14
Thanks for trying to help. Before posting here, I tried to restart, synch, turn on/off the heart rate but nothing seemed to help.
A few days after writing the post the problem seemed to go away (I left the tracker in a drawer for almost a day without doing anything else).
However, there are some problems with it because now the active minutes are back and, as a bonus, sometimes it acts like the side button is pressed (even when it is not on my wrist).
So I am almost ready to give up on Charge 3 and go back to my trusted Flex2. It doesn't have heart rate tracking and all the other featured I hoped to get from the Charge 3 but at least it works and seems to give me the same calorie count for the same effort.
Best Answer05-21-2020 11:38
05-21-2020 11:38
05-22-2020 05:48
05-22-2020 05:48
I know what you mean. I bought the Charge 3 because I was very happy with the Flex 2 and wanted an "upgrade". This morning I woke up to a "dead" device. I plugged it in and saw that the battery was 4% again. Something is definitely wrong here. It is still under warranty, like yours, so I am trying to get support to help me but nothing so far. 😞
This is the second replacement device since I bought it in August, BTW. The first time, it was counting extra floors even when I slept so they replaced it, the second time "dead lines" appeared on the display, and now the third does this weird battery/sensor malfunction thing.
Best Answer05-24-2020 03:57
05-24-2020 03:57
Update: I now have to charge the device every morning. I assume that it's all linked: a defect that causes incorrect readings and drains the battery.
Still waiting for an official reply tthat helps...
Best Answer05-24-2020 18:08
05-24-2020 18:08
I've been encountering the same problem since 3 days ago. My Charge 3 is always reading 2x my heart rate, and the battery drains much faster than before. I didn't do anything special that should have caused this problem, it just suddenly happened.
I tried all the suggested diagnostics steps: rebooting (soft and hard), turning on/off HR tracking, factory reset, unpair/pair, cleaning the sensors, etc. Nothing helped.
06-27-2020 11:17
06-27-2020 11:17
I contacted Fitbit support through a chat (https://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs). They replaced my Charge 3. Good luck to all having difficulty.
07-01-2020 04:28
07-01-2020 04:28
